Display Entity¶
In this submenu you can choose to display only volumes, faces or edges or combine them.
Only Faces
Only Edges
Edges + Faces
If the mesh contains a lot of elements, select Choose… item,
Item to call ‘Display Entity’ dialog box
and Display Entity dialog box will provide a way to display only some entities at the first display instead of displaying all entities, which can take a long time.
‘Display Entity’ dialog allows to select entities before displaying
This menu item is available from the context menu in both Object browser and 3D viewer.
