Cylinders and Pipes Construction
Cylinder
Simple Cylinder
To make a simple cylinder grid in python mode, the following data are required:
  • nbR : number of hexahedra on radial.
  • nbA : number of hexahedra along the perimeter of the cylinder.
  • nbH : number of hexahedra along the axis of the cylinder.
Use the function makeCyinderTop:
elts = doc.makeCylinderTop(nbR, nbA, nbH)
GUI command: Simple Cylinder
Uniform Cylinder
The following data are required:
  • origin : origin’s coordinates of the cylinder (select a vertex).
  • vx : the base of the cylinder (select a vector).
  • vz : the axis of the cylinder (select a vector).
  • rint : the radius of the hole in the cylinder .
  • rext : the radius of the cylinder.
  • angle : angle of the cylinder around the Z axis.
  • hauteur: the height of the cylinder.
Use the function makeCylinderUni to make a uniform cylinder:
elts = doc.makeCylinderUni(origin, vx, vz, rint, rext, angle, hauteur, nbR, nbA, nbH)
GUI command: Uniform Cylinder
Custom Cylinder
  • tr : a list of radiuses in ascendant order.
  • ta : a list of angles in ascendant order.
  • th : a list of heights in ascendant order.
Use the function makeCylinder to make a custom cylinder:
elts = doc.makeCylinder(origin, vx, vz, tr, ta, th)
GUI command: Custom Cylinder
Operations on elts: Elements
Example
# -*- coding: utf-8 -*-
# Copyright (C) 2009-2016  CEA/DEN, EDF R&D
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307 USA
####### Make Cylinder Test ##########
import hexablock
# Simple Cylinder -----
doc  = hexablock.addDocument ("Make Cylinder Test")
nbR = 8
nbA = 10
nbH = 8
cylinder0 = doc.makeCylinderTop (nbR, nbA, nbH)
cylinder0.saveVtk ("makeCylinderTop.vtk")
# Uniform Cylinder -----
origin = doc.addVertex (0, 0, 5)
vx     = doc.addVector (1, 0, 0)
vz     = doc.addVector (0, 0, 1)
rint   = 2
rext   = 4
angle  = 300
hauteur = 1
cylinder1 = doc.makeCylinderUni (origin, vx, vz, rint, rext, angle, hauteur, nbR, nbA, nbH)
cylinder1.saveVtk ("makeCylinderUni.vtk")
# Custom Cylinder
origin = doc.addVertex (5, 0, 0)
tr = [10, 20, 30, 40]
ta = [45, 90, 135, 180, 225]
th = [5, 30, 40, 60]
cylinder2 = doc.makeCylinder(origin, vx, vz, tr, ta, th)
cylinder2.saveVtk("makeCylinder.vtk")
Make Cylinders
To make two cylinders in T shape the following data are required for each cylinder:
  • orig : the origin of the cylinder (select a vertex).
  • h : the height of the cylinder.
One of the two cylinders must be bigger than the other.
Use the function makeCylinders:
elts = doc.makeCylinders (orig1, vz1, rext1, h1, orig2, vz2, rext2, h2)
GUI command: Cylinders
Example
####### Make Cylinders Test ##########
import hexablock
import math
doc  = hexablock.addDocument ("Make Cylinders Test")
rext1 =  2*math.sqrt (2.0)
rext2 =  3*math.sqrt (2.0)
h1   =  16
h2   =  16
xl1  =  -8
orig1  = doc.addVertex ( 0, 0,  xl1)
orig2  = doc.addVertex (-8, 0,  0)
vz1   = doc.addVector ( 0, 0,  1)
vz2   = doc.addVector ( 1, 0,  0)
cylinders = doc.makeCylinders (orig1, vz1, rext1, h1, orig2, vz2, rext2, h2)
cylinders.saveVtk("makeCylinders.vtk")
Pipe
Simple Pipe
To make a simple pipe grid in python mode, the following data are required:
  • nbA : number of hexahedra along the perimeter of the pipe.
  • nbH : number of hexahedra along the axis of the pipe.
Use the function makePipeTop:
elts = doc.makePipeTop(nbR, nbA, nbH)
GUI command: Simple Pipe
Uniform Pipe
  • origin : the origin’s coordinates of the pipe (select a vertex).
  • vx : the base of the pipe (select a vector).
  • vz : the axis of the pipe (select a vector).
  • rint : the radius of the hole in the pipe .
  • rext : the radius of the pipe.
  • angle : angle of the pipe around the Z axis.
  • hauteur: the height of the pipe.
Use the function makePipeUni to make a uniform pipe:
elts = doc.makePipeUni(origin, vx, vz, rint, rext, angle, hauteur, nbR, nbA, nbH)
GUI command: Uniform Pipe
Custom Pipe
  • origin : origin’s coordinates of the pipe (select a vertex).
Use the function makePipe to make a custom pipe:
elts = doc.makePipe(origin, vx, vz, tr, ta, th)
GUI command: Custom Pipe
Example
####### Make Pipe Test ##########
import hexablock
doc  = hexablock.addDocument ("Make Pipe Test")
# Simple Pipe -----
nbR = 8
nbA = 10
nbH = 8
pipe0 = doc.makePipeTop (nbR, nbA, nbH)
pipe0.saveVtk ("makePipeTop.vtk")
# Uniform Pipe -----
orig = doc.addVertex (0, 0, 0)
rint = 1
rext = 3
angle = 360
hauteur = 2
pipe1 = doc.makePipeUni (orig, vx, vz, rint, rext, angle, hauteur, nbR, nbA, nbH)
pipe1.saveVtk ("makePipeUni.vtk");
# Custom Pipe -----
origin = doc.addVertex (0, 5, 0)
pipe2 = doc.makePipe(origin, vx, vz, tr, ta, th)
pipe2.saveVtk("makePipe.vtk")
Make Pipes
To make two pipes in T shape the following data are required for each pipe:
  • orig : the origin of the pipe (select a vertex).
  • rint : the internal radius of the pipe.
  • h : the height of the pipe.
One of the two pipes must be bigger than the other.
Use the function makepipes:
elts = doc.makePipes(orig1, vz1, rint1, rext1, h1, orig2, vz2, rint2, rext2, h2)
GUI command: Pipes
Example
####### Make Pipes Test ##########
import hexablock
import math
doc  = hexablock.addDocument ("Make Pipes Test")
rint1 =  rext1/2
rint2 =  rext1
h1   =  16
h2   =  16
xl1  =  -8
pipes = doc.makePipes (orig1, vz1, rint1, rext1, h1, orig2, vz2, rint2, rext2, h2);
pipes.saveVtk("makePipes.vtk")
