Cut hexahedra
Uniform Cut
To make a uniform cut of an hexahedra in python mode, you need the following arguments:
  • edge : an edge on the hexahedra to cut.
  • nbCuts: the number of cuts.
Use the function cutUni:
elts = doc.cutUni(edge, nbCuts)
GUI command: Uniform Cut
Custom Cut
To make a custom cut of an hexahedra you need the following arguments:
  • edge: an edge on the hexahedra to cut.
  • tl : the list of the lengths of the layers in ascendant order.
Use the funtion cut:
elts = doc.cut(edge, tl)
GUI command: Custom Cut
Operations on elts: Elements
Example
# -*- coding: utf-8 -*-
# Copyright (C) 2009-2016  CEA/DEN, EDF R&D
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307 USA
####### Test for Cut Hexa ###############
import hexablock
doc = hexablock.addDocument("Cut Hexa Test")
size_x = 2
size_y = 1
size_z = 1
grid  = doc.makeCartesianTop (size_x,size_y,size_z)
arete = grid.getEdgeK (0, 0, 0)
doc.saveVtk ("decoupe1.vtk")
nbCuts = 2
grid2 = doc.cutUni (arete, nbCuts)
doc.saveVtk ("decoupe2.vtk")
#tablen = []
#reste  = 1
#abscisse = 0
#for nl in range(5):
#    reste     /= 2
#    abscisse  += reste
#    tablen.append (abscisse)
tablen = [2, 3, 8, 14, 18]
arete = grid2.getEdge(0)
grid3 = doc.cut(arete, tablen)
doc.saveVtk ("decoupe3.vtk")
Table Of Contents
Previous topic
Remove hexahedra
Next topic
Extrude and Join Quadrangles
This Page
