To create a Simple Sphere Grid in python mode, you need the following arguments:
Use the function makeSphereTop:
elts = doc.makeSphereTop(nbR, nbA, nbH)
GUI command: Simple Sphere and Simple Rind
The following data are required:
Use the function makeSphereUni to make a uniform sphere grid:
elts = doc.makeSphereUni (center, vx, vz, rtrou, rext, angle, vplan, nr, na, nh)
GUI command: Uniform Sphere
Use the function makeSphere to make a custom sphere:
elts = doc.makeSphere(center, vx, vz, trad, tang, tphi)
GUI command: Custom Sphere
Operations on elts: Elements
# -*- coding: utf-8 -*-
# Copyright (C) 2009-2016 CEA/DEN, EDF R&D
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
####### Sphere Grid Test ##########
import hexablock
doc = hexablock.addDocument ("Sphere Grid Test")
# Simple Sphere -----
nr = 4
na = 8
nh = 12
sphere0 = doc.makeSphereTop(nr, na, nh)
sphere0.saveVtk("makeSphereTop.vtk")
# Uniform Sphere -----
center = doc.addVertex (0, 0, 0)
vplan = doc.addVertex (0, 0, -0.5)
vx = doc.addVector (1, 0, 0)
vz = doc.addVector (0, 0, 1)
rtrou = 1
rext = 10
angle = 180
sphere1 = doc.makeSphereUni (center, vx, vz, rtrou, rext, angle, vplan, nr, na, nh)
sphere1.saveVtk("makeSphereUni.vtk")
# Custom Sphere -----
dr = (rext-rtrou)/nr
dtheta = angle/na
dphi = 180.0/nh
trad = []
tang = []
tphi = []
for nro in range(nr+1):
trad.append(rtrou + nro*dr)
for nro in range(na+1):
tang.append(nro*dtheta)
for nro in range(nh+1):
tphi.append(-90 + nro*dphi)
sphere2 = doc.makeSphere (center, vx, vz, trad, tang, tphi)
sphere2.saveVtk("makeSphere.vtk")
To create a Simple Rind Grid in python mode, you need the following arguments:
Use the function makeRindTop:
elts = doc.makeRindTop(nbR, nbA, nbH)
Use the function makeRindUni to make a uniform rind grid:
elts = doc.makeRindUni(center, vx, vz, rtrou, rint, rext, angle, vplan, nr, na, nh)
GUI command: Uniform Rind
Use the function makeRind to make a custom rind grid:
elts = doc.makeRind(center, vx, vz, trad, tang, tphi)
GUI command: Custom Rind
####### Rind Grid Test ##########
import hexablock
doc = hexablock.addDocument ("Rind Grid Test")
# Simple Rind -----
nr = 4
na = 8
nh = 12
rind0 = doc.makeRindTop(nr, na, nh)
rind0.saveVtk("makeRindTop.vtk")
# Uniform Rind -----
rtrou = 1
rint = 8
rext = 10
angle = 180
rind1 = doc.makeRindUni(center, vx, vz, rtrou, rint, rext, angle, vplan, nr, na, nh)
rind1.saveVtk("makeRindUni.vtk")
# Custom Rind -----
dtheta = angle/na
dphi = 180.0/nh
trad = []
tang = []
tphi = []
trad.append(rtrou)
trad.append(rint + nro*dr)
rind2 = doc.makeRind(center, vx, vz, trad, tang, tphi)
rind2.saveVtk("makeRind.vtk")
To create a Simple Concentric Grid in python mode, you need the following arguments:
Use the function makeSphericalTop:
elts = doc.makeSphericalTop(nbLayers, crit)
GUI command: Simple Concentric (Spherical)
Use the function makeSphericalUni to make a uniform concentric:
elts = doc.makeSphericalUni(center, vx, vz, rayon, nbLayers, crit)
GUI command: Uniform Concentric (Spherical)
Use the function makeSpherical to make a custom concentric grid:
elts = doc.makeSpherical (center, vx, vz, tr, crit)
GUI command: Custom Concentric (Spherical)
####### Concentric (Spherical) Grid Test ##########
import hexablock
doc = hexablock.addDocument ("Spherical Grid Test")
# Simple Spherical Grid -----
nbLayers = 3
crit = 0
grid0 = doc.makeSphericalTop(nbLayers, crit)
grid0.saveVtk("makeSphericalTop.vtk")
# Uniform Spherical Grid -----
center = doc.addVertex (0, 0, 10)
vz = doc.addVector (0, 1, 1)
rayon = 1
grid1 = doc.makeSphericalUni(center, vx, vz, rayon, nbLayers, crit);
grid1.saveVtk("makeSphericalUni.vtk")
# Custom Spherical Grid-----
tr = [10, 20, 30, 40] # a list of radiuses (one radius for each layer)
grid2 = doc.makeSpherical (center, vx, vz, tr, crit)
grid2.saveVtk("makeSpherical.vtk")
