Rotate and translate for any kind of elements:
elts = doc.makeTranslation(elements, vec)
elts = doc.makeRotation(elements, ver, vec, angle)
elts = doc.makeScale (elements, destination_point, k)
and “element” could be Vertex, Edge, Quadrangle, Hexahedeon, Vector, Cylinder, Pipe and Elements and the result “elts” is always an object of type “Elements”.
Operations on elts: Elements
# -*- coding: latin-1 -*-
# Copyright (C) 2009-2016 CEA/DEN, EDF R&D
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
####### Test make translation ###############
import hexablock
doc = hexablock.addDocument("default")
size_x = 1
size_y = 1
size_z = 2
orig = doc.addVertex(0, 0, 0)
dirVr = doc.addVector(1, 1, 1)
grid = doc.makeCartesian1(orig, dirVr, size_x, size_y, size_z, 0, 0, 0)
##### doc.saveVtk ("cartesian.vtk")
devant = doc.addVector(5, 0, 0)
grid1 = doc.makeTranslation(grid, devant)
##### doc.saveVtk ("translation.vtk")
Translation
####### Test make rotation ###############
import hexablock
size_x = 1
size_y = 1
size_z = 2
##### grid.saveVtk ("initial.vtk")
orig.setScalar(2)
grid1 = doc.makeRotation(grid, orig, dirVr, 60)
##### grid1.saveVtk ("rotation.vtk")
Initial
Rotation
####### Test make scale ###############
import hexablock
doc = hexablock.addDocument ("default")
ori = doc.addVertex ( 0, 0, 0)
vz = doc.addVector ( 0, 0, 1)
vx = doc.addVector ( 1 ,0, 0)
dr = 1
da = 360
dl = 1
nr = 1
na = 6
nl = 1
grid = doc.makeCylindrical (ori, vx,vz, dr,da,dl, nr,na,nl, False)
dest = doc.addVertex (15, 0, 0)
grid2 = doc.makeScale (grid, dest, 0.5)
##### doc .saveVtk ("make_scale.vtk")
Scaling
GUI command: Make elements by transforming elements
