There are three differents ways to make the symmetry of an element:
To make the symmetry of an element by point, you need to define:
elts = doc.makeSymmetryPoint (grid, orig)
Operations on elts: Elements
Here is an example where we make the symmetry of a grid:
# -*- coding: latin-1 -*-
# Copyright (C) 2009-2016 CEA/DEN, EDF R&D
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
######## Make Symmetry Point ########
import hexablock
# ======================================================= make_grid
def make_grid (doc) :
ori = doc.addVertex ( 0, 0, 0)
vz = doc.addVector ( 0, 0, 1)
vx = doc.addVector ( 1 ,0, 0)
dr = 1
da = 360
dl = 1
nr = 1
na = 6
nl = 1
grid = doc.makeCylindrical (ori, vx,vz, dr,da,dl, nr,na,nl, False)
##### doc .saveVtk ("cyl_grid.vtk")
return grid
# ======================================================= test_sym_point
def test_sym_point () :
doc = hexablock.addDocument ("default")
grid = make_grid (doc)
orig = grid.getVertex(3)
grid2 = doc.makeSymmetryPoint (grid, orig)
##### doc .saveVtk ("sym_point.vtk")
return doc
# ================================================================= Begin
doc = test_sym_point ()
To make the symmetry of an element by line, you need to define:
elts = doc.makeSymmetryLine (grid, orig, dir)
######## Make Symmetry Line ########
import hexablock
dr = 1
da = 360
dl = 1
nr = 1
na = 6
nl = 1
return grid
# ======================================================= test_sym_line
def test_sym_line () :
dir = doc.addVector (0, 0, 1);
grid2 = doc.makeSymmetryLine (grid, orig, dir)
##### doc .saveVtk ("sym_line.vtk")
return doc
doc = test_sym_line ()
To make the symmetry of an element by plane, you need to define:
elts = doc.makeSymmetryPlane (grid, orig, dir)
######## Make Symmetry Plane ########
import hexablock
dr = 1
da = 360
dl = 1
nr = 1
na = 6
nl = 1
return grid
# ======================================================= test_sym_plane
def test_sym_plane () :
dir = doc.addVector (0, 1, 0);
grid2 = doc.makeSymmetryPlane (grid, orig, dir)
##### doc .saveVtk ("sym_plane.vtk")
return doc
doc = test_sym_plane ()
