Extrude and Join Quadrangles
There are two different methods to build hexahedra from quadrangles:
  • Extrusion of quadrangles
  • Join two sets of quadrangles
Extrude a quadrangle or quadrangles
Simple Extrude
To extrude one quad or a set of quads the following data are required:
  • quad : the quad to be extruded (for one quad extrusion).
  • quads : the list of quadrangles to be extruded (for multiple quads extrusion).
  • nbLayers: the number of layers of hexahedra resulting from the extrusion.
One quad extrusion:
elts = doc.extrudeQuadTop(quad, nbLayers)
Extrusion of a set of quads:
elts = doc.extrudeQuadsTop(quads, nbLayers)
GUI command: Simple Extrude
Uniform Extrude
The following data are required:
  • dir : the direction of the extrusion.
  • length : the length of hexahedra resulting from the extrusion.
One quad extrusion:
elts = doc.extrudeQuadUni(quad, dir, length, nbLayers)
elts = doc.extrudeQuadsUni(quads, dir, length, nbLayers)
GUI command: Uniform Extrude
Custom Extrude
  • quads: the list of quadrangles to be extruded (for multiple quads extrusion).
  • th : a list of heights (in ascendant order because the size is computed from the origin) to specify the size of each layer of extrusion.
One quad extrusion:
elts = doc.extrudeQuad(quad, dir, th)
elts = doc.extrudeQuads(quads, dir, th)
GUI command: Custom Extrude
Operations on elts: Elements
Example
# -*- coding: utf-8 -*-
# Copyright (C) 2009-2016  CEA/DEN, EDF R&D
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307 USA
####### Test for Extrude Quad ###############
import hexablock
doc = hexablock.addDocument("Extrude Quad Test")
dimx = 11
dimy = 11
dimz = 2
orig1 = doc.addVertex ( 0,0,0)
vx    = doc.addVector ( 1,0,0)
vy    = doc.addVector ( 0,1,0)
vz    = doc.addVector ( 0,0,1)
dir1  = doc.addVector ( 1,1,1)
dir2  = doc.addVector ( 1,1,-1)
dx =1
dy=1
dz=1
grid1 = doc.makeCartesianUni (orig1, vx,vy,vz, dx,dy,dz, dimx,dimy,dimz)
mx = dimx/2
my = dimy/2
liste1 = []
liste2 = []
liste1.append(grid1.getQuadIJ (mx, my, dimz))
liste2.append(grid1.getQuadIJ (mx, my, 0))
for nx in range(dimx):
    if nx!=mx:
        liste1.append(grid1.getQuadIJ (nx, my, dimz))
        liste2.append(grid1.getQuadIJ (nx, my, 0))
for ny in range(dimy):
    if ny!=my:
        liste1.append(grid1.getQuadIJ (mx, ny, dimz))
        liste2.append(grid1.getQuadIJ (mx, ny, 0))
tlen = []
dh0  = 1
dh   = 0.02
lh = 0
for nro in range(5):
    dh = 1.5*dh + 1
    lh += dh
    tlen.append(lh)
nbiter = 5
doc.saveVtk ("prisme1.vtk")
prisme2 = doc.extrudeQuadsUni (liste2, dir2, dh0, nbiter)
doc.saveVtk ("prisme2.vtk")
prisme1 = doc.extrudeQuads (liste1, dir1, tlen)
doc.saveVtk ("prisme3.vtk")
Join quadrangle or quadrangles
Uniform Join
  • quad : the quad to be joined and from which hexahedra will be created (one quad case).
  • quads : the set of quadrangles to be joined and from which hexahedra will be created (multiple quad case).
  • fromPointA: a vertex belonging to the first quadrangle of the set of quadrangles.
  • fromPointB: a vertex, consecutive to previous Point a, belonging to the first quadrangle.
  • quadDest : a quadrangle from the set of targeted quadrangles.
  • toPointA : the target vertex (in the target quadrangle) for fromPointA.
  • toPointB : the target vertex (in the target quadrangle) for fromPointB.
  • nbLayers : number of layers of hexahedra issued from the operation.
To join one quad to an other use the function joinQuadUni:
elts = doc.joinQuadUni(quad, quadDest, fromPointA, fromPointB, toPointA, toPointB, nbLayers)
To join a set of quads to another quad use the function joinQuadsUni:
elts = doc.joinQuadsUni(quads, quadDest, fromPointA, fromPointB, toPointA, toPointB, nbLayers)
GUI command: Uniform Join Quadrangles
Custom Join
  • quads : the set of quadrangles to be joined and from which hexahedra will be created (multiple quads case).
  • th : a list of heights to specify the size of each layer of hexahedra issued from the operation.
To make a custom join of one quad to another use the function joinQuad:
elts = doc.joinQuad(quad, quadDest, fromPointA, fromPointB, toPointA, toPointB, th)
To make a custom join of a set of quads to another quad use the function joinQuads:
elts = doc.joinQuads(quads, quadDest, fromPointA, fromPointB, toPointA, toPointB, th)
GUI command: Custom Join Quadrangles
Example
####### Test for Join Quad ###############
import hexablock
doc = hexablock.addDocument("Join Quad Test")
dimx = 11
dimy = 11
dimz = 2
grid1 = doc.makeCartesianTop (dimx,dimy,dimz)
orig2 = doc.addVertex(dimx/2.0,0,8)
vectj = doc.addVector (0,1,0);
vecti = doc.addVector (1,0,0);
grid2 = doc.makeCylinderUni (orig2, vecti, vectj, 1.0, 2.0, 180.0, 11.0, dimz,dimy,dimx)
mx = dimx/2
my = dimy/2
prems = grid1.getQuadIJ (mx, my, dimz)
cible = grid2.getQuadJK (dimz, mx, my)
va1 = prems.getVertex (0)
va2 = prems.getVertex (1)
vb1 = cible.getVertex (1)
vb2 = cible.getVertex (2)
hauteur = 5
liste = []
liste.append(prems)
for nx in range(mx):
    if nx!=mx:
        liste.append(grid1.getQuadIJ(nx, my, dimz))
    if (ny!=my):
        liste.append(grid1.getQuadIJ (mx, ny, dimz))
doc.saveVtk ("jointQuad1.vtk")
joint = doc.joinQuadsUni (liste, cible, va1,vb1,va2,vb2, hauteur)
doc.saveVtk ("jointQuad2.vtk")
