Curve
To create a Curve in the Main Menu select New Entity - > Basic - > Curve
There are three Curve Construction menu choices corresponding to three possible types of curves: Polyline, Besier or B-spline (Interpolated). The curve is defined by a list of Points through which it passes.
There are two ways to define these Points:
  • By Selection manual picking of the points in the Object Browser or 3D Viewer.
  • Analytical parametric definition of the points through python expressions.
The Result of each operation will be a GEOM_Object (edge).
Polyline
Polyline or polygonal chain is a connected series of line segments. It can be defined by the following parameters:
  • Points at least 2 points which will serve as nodes on the curve.
  • Build a closed wire checkbox allows creating the curve as closed wire.
TUI Command: geompy.MakePolyline(ListOfShapes,isClosed)
Bezier
Bezier curve is a curve completely contained in a convex hull of its control points. It can be defined by the following parameters:
  • Points at least 2 points used to approximate the curve.
  • Build a closed edge checkbox allows creating the curve as closed edge.
TUI Command: geompy.MakeBezier(ListOfShapes,isClosed)
B-spline
B-spline is a union of curve segments defined at each node span. It can be defined by the following parameters:
  • If Reorder vertices taking into account distances is checked, the interpolation algorithm does not follow the order of vertices but searches for the closest vertex.
  • Tangents are two vectors, defining the direction at the ends of the curve. It is necessary to set both vectors or none. This option is available only if both above check boxes are not checked.
TUI Command:
geompy.MakeInterpol(ListOfShapes,isClosed,doReordering)
geompy.MakeInterpolWithTangents(ListOfShapes,Vector1,Vector2)
Analytical Definition
The input parameters for analytical definition are common for all types of curves.
  • X(t)equation, Y(t)equation, Z(t)equation are python expressions for X, Y and Z coordinates of the basic points of the curve.
  • Min t, Max t are minimum and maximum values of the parameter t.
  • Step is the number of steps of the parameter t.
TUI Command: geompy.MakeCurveParametric(XExpr, YExpt, ZExpt, tMin, tMax, nbSteps, curveType, True)
Advanced options Preview
Our TUI Scripts provide you with useful examples of creation of Basic Geometric Objects.
