Version: 9.15.0
Cylinder
To create a Cylinder in the Main Menu select New Entity - > Primitives - > Cylinder
There are 2 algorithms for creation of a Cylinder.
The Result of each operation will be a GEOM_Object (SOLID).
Firstly, you can define a Cylinder by the Base Point (the central point of the cylinder base), the Vector (the axis of the cylinder), and its dimensions: the Radius and the Height. You can optionally specify the Angle to create a portion of cylinder.
TUI Command: geompy.MakeCylinder(Point, Axis, Radius, Height)
Arguments: Name + 1 vertex + 1 vector + 2 values (Dimensions: radius and height).
TUI Command: geompy.MakeCylinderA(Point, Axis, Radius, Height, Angle)
Arguments: Name + 1 vertex + 1 vector + 3 values (Dimensions: radius, height and angle).
Secondly, you can define a Cylinder by the given Radius and Height at the origin of coordinate system. The axis of the cylinder will be collinear to the OZ axis of the coordinate system. Similarly to the first constructor, you can optionally specify the Angle to create a portion of cylinder.
TUI Command: geompy.MakeCylinderRH(Radius, Height)
Arguments: Name + 2 values (Dimensions at origin: radius and height).
TUI Command: geompy.MakeCylinderRHA(Radius, Height, Angle)
Arguments: Name + 3 values (Dimensions at origin: radius, height and angle).
Example:
Cylinders
Our TUI Scripts provide you with useful examples of creation of Primitives.
