Fillet 1D
This operation creates fillets on the corners of a Wire with Planar Edges. Note that each couple of edges connected with a vertex, where 1D fillet should be constructed, have to lie in the same plane.
To produce a Fillet 1D in the Main Menu select Operations - > Fillet 1D
Define the Wire with planar Edges to create a fillet on, select the necessary vertexes on this wire in the OCC Viewer and define the Radius of the Fillet.
Note: This Operation Works for the Wires with Planar Edges only.
Note: Use option Fuse collinear edges to allow bigger radius in order to ignore possible secant points, i.e. the joints of collinear edges, thus processing such edges as one.
TUI Command: geompy.MakeFillet1D(Shape, R, ListVertexes)
Arguments: Name + 1 shape + empty list or several vertexes + 1 value (Fillet radius).
Advanced options: Preview
Examples:
Filleted Wire
