Fillet 3D
To produce a Fillet in the Main Menu select Operations - > Fillet
This operation creates fillets on the edges of a shape.
To create fillets on all edges of the given shape, you need to select the Main Object to create a fillet on and to define the Radius of the Fillet.
TUI Command: geompy.MakeFilletAll(Shape, R)
Arguments: Name + 1 shape + 1 value (fillet radius).
Advanced options Preview
To create fillets on the specified edges or faces of the given shape, you need to define the Main Object to create a fillet on, select the necessary edges or faces in the OCC Viewer and define the Radius of the Fillet.
TUI Command: geompy.MakeFillet(Shape, R, ShapeType, ListShapes)
Arguments: Name + 1 shape + one or several edges (or faces)
  • 1 value (Fillet radius).
Alternatively, there is a possibility to create a fillet with a variable radius. For this, toggle the lower radio button and define R1 (the radius at the start of the selected edge(s)) and R2 (the radius at the end of the selected edge(s))
Examples:
Fillet on all
Fillet on an edge
Fillet on a Face
