Shape Proximity
The Shape Proximity operation calculates maximal of all possible distances between two shapes. Considering this case :
The proximity of blue shape to the red one is computed like this : For each point of blue the distance to the red is computed using perpendicular projection. The proximity value returned is equal to maximal value of all of this distances. To do that the implemented algorithm
1 - sampling shapes by points then calculating the distance from each sample point from one shape to another
2 - find the position which gives the maximal distance
3 - improve the proximity value basing on the exact shapes using the points found on step 2 as a start position
It may happen that for some point of blue shape no distance to red shape exist using perpendicular projection. This is typically the case here :
In the case of no perpendicular projection of a point on blue shape exists, instead of perpendicular projection the minimal distance to border point of red shape is considered. The distance from EndBlue Point is taken using EndRed Point (black line represents the distance for EndBlue).
This is just a TUI functionality. The provided class
geompy.ShapeProximity()
has an interface to compute proximity value with default parameters
p = geompy.ShapeProximity()
value = p.proximity(shape1, shape2)
Moreover, it also provides the functionality to customize the calculation. For example, compute coarse proximity value basing on the number of sampling points for each shape, or compute the precise value as a refining operation after the coarse value calculation.
p.setShapes(shape1, shape2) # customize calculator with input shapes
p.setSampling(shape1, 100)  # assign number of sample points for the first shape
p.setSampling(shape2, 25)   # assign number of sample points for the second shape
coarse_proximity = p.coarseProximity() # rough proximity value basing on the shape sampling and tessellation
fine_proximity = p.preciseProximity()  # more precise proximity value using exact shapes
See also a TUI example.
