Get Shapes on Shape
This operation is a special case of Explode operation. It produces a group of sub-shapes of the exploded shape, which are located in a definite way relatively another reference shape. The reference shape should be a solid.
To use this operation, select in the Main Menu Operations -> Get Shapes on Shape. The following dialog box will appear.
  • Name is the name of the resulting group of shapes;
  • Shape for exploding is the shape that will be exploded;
  • Solid for checking is the reference shape, which should be a solid;
  • Reconstruction Limit is the type of created sub-shapes: solid, shell, face, wire, edge, vertex;
  • State is the position of the created sub-shapes relatively the reference shapes:
    • IN - the created sub-shapes are located inside the reference shape;
    • OUT - the created sub-shapes are located outside the reference shape;
    • ON - the created sub-shapes lie on the reference shape;
    • ONIN - the created sub-shapes lie on the reference shape or are located inside it;
    • ONOUT - the created sub-shapes lie on the reference shape or are located outside it;
Advanced options Preview
Example:
In the images below the box is the exploded shape and the cylinder is the reference shape. In the first image the edge IN the reference cylinder is highlighted in red, in the second the edges OUT of the reference cylinder are highlighted.
