Using Find Tool¶
The Object Browser is supplied with the Find toolbox. This tool allows performing context search of the items in the Object Browser:
The Find toolbox can be invoked in several ways:
Pressing Ctrl-F key combination starts a new search; the text previously input by the user in the edit control of the Find toolbox is automatically selected.
Pressing / (slash) key starts a new search; the text previously input by the user is cleared.
Pressing F3 key repeats the previous search in the forward direction (from top to bottom).
Pressing Shift-F3 key repeats the previous search in the backward direction (from bottom to top).
Activating Find command from the Object Browser context popup menu starts a new search (the same as Ctrl-F).
Pressing Escape key closes the Find toolbox.
The search is always started from the first selected item in the Object Browser. If there are no selected items, the search is started from the top of the Object Browser contents. If there is an item which satisfies the search conditions, it is selected and the Object Browser is expanded to show this item (if it is collapsed).
The Find toolbox provides a set of widgets which are used to perform the search operations or change the search conditions:
“Close” button closes the Find toolbox.
Line edit box is used to input the searched text. Note that the search is always done by the object name, i.e. by the data displayed in the “Name” column of the Object Browser.
“Find first item” button searches the very first item which satisfies the search conditions.
“Find previous item” button searches the previous item which satisfies the search conditions.
“Find next item” button searches the next item which satisfies the search conditions.
“Find last item” button searches the very last item which satisfies the search conditions.
“Case sensitive” check box allows performing case sensitive search.
“Regular Expression” check box allows performing the search of the items by the regular expression, for example:
Face - matches all faces
Face_[\d] - matches Face_1, Face_2, etc.. (all faces)
Face_[\d]$ - matches Face_1, Face_2, but does not match Face_11, Face_12.
^Face_[\d]$ - the same as above
^ Face_[\d]$ - matches nothing
“Wrap search” check box: if checked and the search reaches the last item, satisfying the search conditions, pressing “Find Next” button moves the selection to the very first item which matches the search conditions (i.e. a cyclic search is performed).
If there are no items satisfying the search conditions in the Object Browser, the edit control of the Find toolbox becomes red-colored:
The Find toolbox also has an auto-hiding feature. This works as follows:
If the input focus is inside the Find toolbox, auto-hiding is automatically deactivated.
If the input focus moves outside the Find toolbox, it hides automatically in 10 seconds after the last search operation (which can be done by clicking * “Find Next”, *”Find Previous” button, or typing something in the edit field); each new search operation restarts the auto-hide timer.
