Cut hexahedra¶
Uniform Cut¶
To make a uniform cut of an hexahedra in python mode, you need the following arguments:
edge : an edge on the hexahedra to cut.
nbCuts: the number of cuts.
Use the function cutUni:
elts = doc.cutUni(edge, nbCuts)
GUI command: Uniform Cut
Custom Cut¶
To make a custom cut of an hexahedra you need the following arguments:
edge: an edge on the hexahedra to cut.
tl : the list of the lengths of the layers in ascendant order.
Use the funtion cut:
elts = doc.cut(edge, tl)
GUI command: Custom Cut
Operations on elts: Elements
Example¶
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 | # -*- coding: utf-8 -*-
# Copyright (C) 2009-2025 CEA, EDF
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
####### Test for Cut Hexa ###############
import hexablock
doc = hexablock.addDocument("Cut Hexa Test")
size_x = 2
size_y = 1
size_z = 1
grid = doc.makeCartesianTop (size_x,size_y,size_z)
arete = grid.getEdgeK (0, 0, 0)
doc.saveVtk ("decoupe1.vtk")
nbCuts = 2
grid2 = doc.cutUni (arete, nbCuts)
doc.saveVtk ("decoupe2.vtk")
#tablen = []
#reste = 1
#abscisse = 0
#for nl in range(5):
# reste /= 2
# abscisse += reste
# tablen.append (abscisse)
tablen = [2, 3, 8, 14, 18]
arete = grid2.getEdge(0)
grid3 = doc.cut(arete, tablen)
doc.saveVtk ("decoupe3.vtk")
