Make Symmetry
There are three differents ways to make the symmetry of an element:
  • Symmetry by point
  • Symmetry by line
  • Symmetry by plane
Symmetry by point
To make the symmetry of an element by point, you need to define:
  • the element
  • the symmetry center
elts = doc.makeSymmetryPoint (grid, orig)
Operations on elts: Elements
Here is an example where we make the symmetry of a grid:
Example
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
20
21
23
24
26
27
28
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
# -*- coding: latin-1 -*-
# Copyright (C) 2009-2025  CEA, EDF
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307 USA
######## Make Symmetry Point ########
import hexablock
# ======================================================= make_grid
def make_grid (doc) :
    ori  = doc.addVertex ( 0, 0, 0)
    vz   = doc.addVector ( 0, 0, 1)
    vx   = doc.addVector ( 1 ,0, 0)
    dr = 1
    da = 360
    dl = 1
    nr = 1
    na = 6
    nl = 1
    grid = doc.makeCylindrical (ori, vx,vz, dr,da,dl, nr,na,nl, False)
    #####  doc .saveVtk ("cyl_grid.vtk")
    return grid
# ======================================================= test_sym_point
def test_sym_point () :
    doc  = hexablock.addDocument ("default")
    grid = make_grid (doc)
    orig = grid.getVertex(3)
    grid2 = doc.makeSymmetryPoint (grid, orig)
    #####  doc .saveVtk ("sym_point.vtk")
    return doc
# ================================================================= Begin
doc = test_sym_point  ()
Result
_images/grid.png
Initial
_images/make_sym_point.png
Symmetry of a grid by point
Symmetry by line
To make the symmetry of an element by line, you need to define:
  • the element
  • a point and a direction to define the line of symmetry
elts = doc.makeSymmetryLine (grid, orig, dir)
Example
Code
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
20
21
23
24
26
27
28
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
######## Make Symmetry Line ########
import hexablock
    dr = 1
    da = 360
    dl = 1
    nr = 1
    na = 6
    nl = 1
    return grid
# ======================================================= test_sym_line
def test_sym_line () :
    dir   = doc.addVector (0, 0, 1);
    grid2 = doc.makeSymmetryLine (grid, orig, dir)
    #####  doc .saveVtk ("sym_line.vtk")
    return doc
doc = test_sym_line  ()
Result
_images/make_sym_line.png
Symmetry of a grid by line
Symmetry by plane
To make the symmetry of an element by plane, you need to define:
  • the element
  • a point and a direction to define the plane of symmetry
elts = doc.makeSymmetryPlane (grid, orig, dir)
Example
Code
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
20
21
23
24
26
27
28
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
######## Make Symmetry Plane ########
import hexablock
    dr = 1
    da = 360
    dl = 1
    nr = 1
    na = 6
    nl = 1
    return grid
# ======================================================= test_sym_plane
def test_sym_plane () :
    dir   = doc.addVector (0, 1, 0);
    grid2 = doc.makeSymmetryPlane (grid, orig, dir)
    #####  doc .saveVtk ("sym_plane.vtk")
    return doc
doc = test_sym_plane  ()
Result
_images/make_sym_plane.png
Symmetry of a grid by plane
GUI command: Make elements by symmetry
