Quad Revolution¶
Uniform Quad Revolution¶
To make a uniform quad revolution you need:
quad : the quadrangle from which hexahedrons will be created (only for one quad revolution).
quads : a set of quadrangles from which hexahedrons will be created (only for multiple quads revolution).
center : center of rotation (a vertex).
axis : axis of rotation (a vector).
angle : Specify the rotation’s angle at each step.
nbLayers: the number of steps.
One quad revolution:
elts = doc.revolutionQuadUni(quad, center, axis, angle, nbLayers)
Revolution of a set of quads:
elts = doc.revolutionQuadsUni(quads, center, axis, angle, nbLayers)
GUI command: Uniform Quad Revolution
Custom Quad Revolution¶
To make a custom quad revolution you need:
angles : a set of angles (in degrees). Specify the rotation’s angle at each step.
elts = doc.revolutionQuad(quad, center, axis, angles)
elts = doc.revolutionQuads(quads, center, axis, angles)
GUI command: Custom Quad Revolution
Operations on elts: Elements
Example¶
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 | # -*- coding: utf-8 -*-
# Copyright (C) 2009-2025 CEA, EDF
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
#### Quad Revolution Test #####
import hexablock
doc = hexablock.addDocument("Quad Revolution Test")
center = doc.addVertex(0, 0, 0)
vz = doc.addVector(0, 0, 1)
v1 = doc.addVertex (10, 0, 0)
v2 = doc.addVertex (11, 0, 0)
v3 = doc.addVertex (11, 0, 2)
v4 = doc.addVertex (10, 0, 2)
quad = doc.addQuadVertices (v1, v2, v3, v4)
doc.saveVtk("revolution1.vtk")
angle = 180
nbLayers = 8
grid0 = doc.revolutionQuadUni (quad, center, vz, angle, nbLayers)
doc.saveVtk ("revolution2.vtk")
nr = 1
na = 6
nl = 1
grid = doc.makeCylinderTop (nr,na,nl)
liste = []
for nx in range(nr):
for ny in range(na):
cell = grid.getQuadIJ (nx, ny, nl)
liste.append(cell)
center = doc.addVertex(0, -10, 0)
axis = doc.addVector (1, 0, 0)
angle = 180
nbLayers = 9
grid1 = doc.revolutionQuadsUni (liste, center, axis, angle, nbLayers)
if grid1.isValid():
doc.saveVtk ("revolution3.vtk")
