Field templates in MEDCoupling
This concept appears in ICOCO API. A field template is the adequate data structure to perform costly interpolation matrix computation as Remapper class does. A field template can be seen as field without its double values. The double values are only used for light matrix vector multiplication.
Concretely a field template is a pair containing :
  • a mesh
  • a spatial discretization (on cells, on nodes, on Gauss points (including localizations, reference elements), )
TODO enhance here
