INTERP_KERNEL::Node Member List
This is the complete list of members for INTERP_KERNEL::Node, including all inherited members.
_cntINTERP_KERNEL::Nodemutableprotected
_coordsINTERP_KERNEL::Nodeprotected
_hitINTERP_KERNEL::Nodemutableprotected
_locINTERP_KERNEL::Nodemutableprotected
applySimilarity(double xBary, double yBary, double dimChar)INTERP_KERNEL::Node
areDoubleEquals(double a, double b)INTERP_KERNEL::Nodestatic
areDoubleEqualsWPLeft(double a, double b, double k)INTERP_KERNEL::Nodestatic
areDoubleEqualsWPRight(double a, double b, double k)INTERP_KERNEL::Nodestatic
computeAngle(const double *pt1, const double *pt2)INTERP_KERNEL::Nodestatic
computeSlope(const double *pt1, const double *pt2)INTERP_KERNEL::Nodestatic
declareIn() constINTERP_KERNEL::Node
declareOn() constINTERP_KERNEL::Node
declareOnLim() constINTERP_KERNEL::Node
declareOnTangent()INTERP_KERNEL::Node
declareOut()INTERP_KERNEL::Node
decrRef()INTERP_KERNEL::Node
distanceBtw2Pt(const double *a, const double *b)INTERP_KERNEL::Nodestatic
distanceBtw2PtSq(const double *a, const double *b)INTERP_KERNEL::Nodestatic
distanceWithSq(const Node &other) constINTERP_KERNEL::Node
dot(const double *vect1, const double *vect2)INTERP_KERNEL::Nodestatic
dumpInXfigFile(std::ostream &stream, int resolution, const Bounds &box) constINTERP_KERNEL::Node
fillGlobalInfoAbs(const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > &mapAddCoo, mcIdType *nodeId) constINTERP_KERNEL::Node
fillGlobalInfoAbs2(const std::map< INTERP_KERNEL::Node *, mcIdType > &mapThis, const std::map< INTERP_KERNEL::Node *, mcIdType > &mapOther, mcIdType offset1, mcIdType offset2, double fact, double baryX, double baryY, std::vector< double > &addCoo, std::map< INTERP_KERNEL::Node *, mcIdType > &mapAddCoo, std::vector< mcIdType > &pointsOther) constINTERP_KERNEL::Node
getHitStatus() constINTERP_KERNEL::Node
getLoc() constINTERP_KERNEL::Node
getSlope(const Node &other) constINTERP_KERNEL::Node
hitMeAfter(double xBary, double yBary, double dimChar)INTERP_KERNEL::Node
hitMeAlone(double xBary, double yBary, double dimChar)INTERP_KERNEL::Node
incrRef() constINTERP_KERNEL::Node
initHitStatus() constINTERP_KERNEL::Node
initLocs() constINTERP_KERNEL::Node
isEqual(const Node &other) constINTERP_KERNEL::Node
isEqualAndKeepTrack(const Node &other, std::vector< Node * > &track) constINTERP_KERNEL::Node
Node(double x, double y)INTERP_KERNEL::Node
Node(const double *coords)INTERP_KERNEL::Node
Node(std::istream &stream)INTERP_KERNEL::Node
norm(const double *vect)INTERP_KERNEL::Nodestatic
operator const double *() constINTERP_KERNEL::Node
operator[](int i) constINTERP_KERNEL::Node
setLoc(TypeOfLocInPolygon loc) constINTERP_KERNEL::Node
setNewCoords(double x, double y)INTERP_KERNEL::Node
sign(double val)INTERP_KERNEL::Nodestatic
unApplySimilarity(double xBary, double yBary, double dimChar)INTERP_KERNEL::Node
unHitMeAfter(double xBary, double yBary, double dimChar)INTERP_KERNEL::Node
unHitMeAlone(double xBary, double yBary, double dimChar)INTERP_KERNEL::Node
~Node()INTERP_KERNEL::Nodeprotected
