Loading...
Searching...
No Matches
DividedCylinder
The Divided cylinder object is a cylinder divided into blocks for easy hexahedral meshing. Two division patterns are available :
  • A square pattern, which is frequently used;
  • A hexagonal pattern, which ensures a better mesh quality and especially less acute or obtuse angles.
To create a DividedCylinder in the Main Menu select New Entity - > Advanced - > DividedCylinder
Specify the parameters of the DividedCylinder object creation in the opened dialog box and press "Apply" or "Apply & Close" button. Result of each operation will be a GEOM_Object.
TUI Command: geompy.MakeDividedCylinder(R, H, Pattern)
Arguments:
  • R - Radius of the cylinder
  • H - Height of the cylinder
  • Pattern - Division pattern
Our TUI Scripts provide you with useful examples of creation of Advanced objects.
