Loading...
Searching...
No Matches
Hexaedral solid
This operation allows to build a hexahedral solid bypassing the intermediate stage of building a shell and 4 faces (in case of building by 2 faces) or just a shell (in case of building by 6 faces).
There are 2 algorithms to create a hexahedral solid in the 3D space.
The Result of the operation will be a GEOM_Object (solid).
Firstly, you can define a Hexahedral Solid by two faces, other four faces are created automatically.
TUI Command: geompy.MakeHexa2Faces(F1, F2), Arguments: Name + 2 Faces.
Example:
Hexahedral Solid built on the base of two Faces
Secondly, you can define a Hexahedral Solid by all six faces.
TUI Command: geompy.MakeHexa(F1, F2, F3, F4, F5, F6), Arguments: Name + 6 Faces.
Example:
Hexahedral Solid built on the base of six Faces
The created blocks can be processed with Operations on Blocks.
Our TUI Scripts provide you with useful examples of Building by Blocks.
