Loading...
Searching...
No Matches
Isoline
Isoline is a 3D curve built on a bounded face limited by [Umin, Umax] and [Vmin, Vmax] values of U and V parameters. For all points of the isoline U or V parameter value is constant.
Result of this operation is either a single edge or a compound of edges.
To create an Isoline of a face in the Main Menu select New Entity - > Basic - > Isoline.
In this dialog:
  • Input or accept the default Name of the resulting shape.
  • Click the arrow button and select in the Object Browser or in the Viewer the Face, for which the Isoline is built.
  • Select along which coordinate: U-Isoline or V-Isoline the Isoline is built;
  • Set Parameter (ranging from 0 to 1), which defines the proportion, at which a face is divided by the isoline. If Parameter=0.5, the isoline is a median.
  • Press "Apply" or "Apply & Close" button to get the result (an edge or a compound of several edges).
This operation can be performed using a TUI Command:
geompy.MakeIsoline(theFace, IsUIsoline, theParameter)
Arguments: Name + Face + Type (True for U-Isoline; False for V-Isoline) + Parameter.
Example:
Isoline on a rectangle face
Our TUI Scripts provide you with useful examples of creation of Basic Geometric Objects.
