Loading...
Searching...
No Matches
Line
To create a Line in the Main Menu select New Entity - >Basic - > Line
There are 2 algorithms to create a Line in the 3D space. The Result of each operation will be a GEOM_Object (edge).
Firstly you can define a Line by Point1 and Point2, which are the points through which the Line passes.
TUI Command: geompy.MakeLineTwoPnt(Point1, Point2)
Arguments: Name + 2 vertices.
Secondly you can define a Line as intersection of Plane1 and Plane2.
TUI Command: geompy.MakeLineTwoFaces(myFace1, myFace2)
Arguments: Name + 2 faces.
Example:
Line defined through points
NB! There is another way to create a line, which is currently accessible only via TUI commands.
You can define a line passing through the given Point and parallel to the given Vector.
TUI Command: geompy.MakeLine(Point, Vector)
Our TUI Scripts provide you with useful examples of creation of Basic Geometric Objects.
