Loading...
Searching...
No Matches
Quadrangle face
This operation allows to build a face bypassing the intermediate stage of building edges and wires (in case of building by 4 points) or wires (in case of building by 4 or 2 edges).
There are 3 algorithms to create a Quadrangle Face in the 3D space.
The Result of each op
The created blocks can be processed with Operations on Blocks.
Our TUI Scripts provide you with useful examples of Building by Blocks
Our TUI Scripts provide you with useful examples of Building by Blocks. age "Building by Blocks". eration will be a GEOM_Object (face).
Firstly you can define a Quadrangle Face by four vertices. Edges are created automatically.
TUI Command: geompy.MakeQuad4Vertices(V1, V2, V3, V4), Arguments: Name + 4 Points.
Secondly, you can define a Quadrangle Face by two edges, while the other two edges are created automatically. TUI Command: geompy.MakeQuad2Edges(E1, E2) Arguments: Name + 2 Edges.
Finally, you can define a Quadrangle Face by four edges.
TUI Command: geompy.MakeQuad(E1, E2, E3, E4),. Arguments: Name + 4 Edges.
Example:
Quadrangle face built by blocks
