Loading...
Searching...
No Matches
Rectangle
A primitive called Rectangle is a rectangular face of certain dimensions and orientation
To create a Rectangle in the Main Menu select New Entity - > Primitives - > Rectangle
There are 2 algorithms to create a Rectangle in the 3D space.
The Result of each operation will be a GEOM_Object (Face).
Firstly, you can create a Rectangle at the origin of coordinates defining its boundaries by the height and the width and its axis by the orientation radio buttons (OXY, OYZ or OZX).This means that the Rectangle will lie in "OXY", "OYZ" or "OZX" plane correspondingly.
TUI Command: geompy.MakeFaceHW(Height, Width, Orientation)
Arguments: Name + 3 values (Dimensions at origin: height, width and orientation).
Secondly, you can define a Rectangle by the height and the width sizes and an Edge defining the normal to the center of the face.
TUI Command: geompy.MakeFaceObjHW(Vector, Height, Width)
Arguments: Name + 1 Vector (normal to the center) + 2 doubles (to describe a face sizes).
It is also possible to create a Rectangle from another selected face. For this, switch the Object Type button to Face, then select a face object and set the values of Height and Width for the new face. The created face will lie in the plane of the selected face.
TUI Command: geompy.MakeFaceObjHW(Face, Height, Width)
Arguments: Name + 1 Face + 2 parameters (to describe a face sizes).
Example:
Rectangle
Our TUI Scripts provide you with useful examples of creating Primitives.
