Loading...
Searching...
No Matches
Thickness Construction
To add Thickness to a shape in the Main Menu select New Entity - > Generation - > Thickness.
Switch between adding thickness to a Face (Shell) or a Solid using radio buttons.
Firstly, Thickness can be applied to a Face or a Shell to create a Solid.
It is necessary to define an Object (Face or Shell) and the value of Thickness. Thicken towards the inside check box allows changing the thickness direction.
Example:
Thickness of Shell
Secondly, the Thickness can be applied to a Solid to create a hollowed Solid.
It is necessary to define a Solid Object Faces to be removed from the result and Thickness. Thicken towards the inside check box allows changing the thickness direction.
Example:
Thickness of Solid
TUI Commands:
geompy.MakeThickSolid(theShape, theThickness, theFacesIDs=[]) - Makes a thick solid from a shape;
geompy.Thicken(theShape, theThickness, theFacesIDs=[]) - Modifies a shape to make it a thick solid.
Arguments: Name + 1 shape (face, shell or solid) + thickness + the list of face IDs.
If the shape is a face or a shell the list of face IDs is not used. The thickness can be positive or negative for thickening towards the inside.
Advanced options Preview
Our TUI Scripts provide you with useful examples of creation of Complex Geometric Objects.
