Loading...
Searching...
No Matches
Torus
To create a Torus in the Main Menu select New Entity - > Primitives - > Torus
There are two algorithms for creation of a Torus.
The Result of each operation will be a GEOM_Object (SOLID).
Firstly, you can define a Torus by the given Base Point, the normal Vector and the Major and Minor Radiuses.
TUI Command: geompy.MakeTorus(Point, Vector, RadiusMajor, RadiusMinor)
Arguments: Name + 1 vertex + 1 vector (for direction) + 2 values (1 & 2 Radius).
Secondly, you can define a Torus with the center at the origin of coordinates by its Major and Minor Radiuses.
TUI Command: geompy.MakeTorusRR(RadiusMajor, RadiusMinor)
Arguments: Name + 2 values (1 & 2 Radius from the origin).
Example:
Toruses
Our TUI Scripts provide you with useful examples of creation of Primitives.
