Loading...
Searching...
No Matches
Vector
To create a Vector in the Main Menu select New Entity - > Basic - > Vector
There are 2 algorithms to create a Vector in the 3D space.
The Result of each operation will be a GEOM_Object (edge).
Firstly, you can define a Vector by its Start and End Points.
TUI Command: geompy.MakeVector(Point1, Point2)
Arguments: Name + 2 vertices.
Secondly, you can define a Vector starting in the Origin of coordinates by its End Point.
TUI Command: geompy.MakeVectorDXDYDZ(DX, DY, DZ)
Arguments: Name + 3 values
Example:
A vector by two points and a vector from the origin of coordinates
Our TUI Scripts provide you with useful examples of creation of Basic Geometric Objects.
