Loading...
Searching...
No Matches
Modifying Geometry Python scripts from SALOME 6 and before
In SALOME 7.2, the Python interface for Geometry has been slightly modified to offer new functionality:
Scripts generated for SALOME 6 and older versions must be adapted to work in SALOME 7.2 with full functionality.
The compatibility mode allows old scripts to work in almost all cases, but with a warning.
Salome initialisation must always be done as shown below
(salome_init() can be invoked safely several times):
from salome.kernel import salome
salome.salome_init()
Geometry initialisation is modified.
the old mode:
import geompy
geompy.init_geom()
the new mode:
from salome.kernel import GEOM
geompy = geomBuilder.New()
Of course, from geompy import * is no more possible.
You have to explicitly write geompy.some_method().
Some variables have been transferred from the namespace geompy.GEOM to the namespace GEOM.
All occurrences of geompy.GEOM. can be replaced by GEOM..
For instance:
param_polyline = geompy.MakeCurveParametric("t", "sin(t)", "cos(t)", 0., 100., 100, geompy.GEOM.Polyline, theNewMethod=True)
is replaced by:
param_polyline = geompy.MakeCurveParametric("t", "sin(t)", "cos(t)", 0., 100., 100, GEOM.Polyline, theNewMethod=True)
