Loading...
Searching...
No Matches
Multi Rotation
To produce a Multi Rotation in the Main Menu select Operations - > Transformation - > Multi Rotation
This operation creates a compound of several rotated shapes basing on the initial shape.
In case of Simple Multi Rotation the object is multiplied by rotation.
The following parameters and options can be defined in this dialog:
  • Result Name;
  • Main Object to be rotated;
  • Vector defines the axis of rotation (DZ by default);
  • Angular step is the angle by which the object is rotated. By default (if the checkbox is not checked), it is 2 * PI / NbTimes;
  • Nb. Times is the number of rotated shape copies in the resulting compound. If NbTimes = 1, the result contains only the initial shape;
  • Advanced options.
The Result will be a GEOM_Object (compound).
TUI Commands:
geompy.MultiRotate1DNbTimes(Shape, Axis, NbTimes)
geompy.MultiRotate1DByStep(Shape, Axis, AngleStep, NbTimes)
NB! There is another way to execute a Multi-rotation operation, which is currently accessible only via TUI commands: geompy.MakeMultiRotation1DNbTimes(Shape, Dir, Point, NbTimes), geompy.MakeMultiRotation1DByStep(Shape, Dir, Point, AngleStep, NbTimes), which works in the same way, but the Axis is defined by direction and point.
The initial object
The result of a simple multi-rotation
In case of Double Multi Rotation the object is multiplied by rotation and additionally translated several times in each direction.
  • Result Name;
  • Nb. Times (NbTimes1) is the number of rotated shape copies in the resulting compound;
  • Reverse checkbox allows changing the direction of translation;
  • Radial step is the distance between the shape copies in the same direction. Translation direction passes through the center of gravity of the initial shape and its projection on the rotation axis;
  • Nb. Times (NbTimes2) is the number of shape copies in the same direction. If NbTimes2 = 1, the result is the same as for Simple Multi Rotation. If both NbTimes1 and NbTimes2 are equal to 1, the result will contain only the initial non-transformed shape;
  • Advanced options.
TUI Commands:
geompy.MultiRotate2DNbTimes(Shape, Axis, NbTimes1, RadialStep, NbTimes2)
geompy.MultiRotate2DByStep(Shape, Axis, AngleStep, NbTimes1, RadialStep, NbTimes2)
NB! There is another way to execute a Double Multi-rotation operation, which is currently accessible only via TUI commands: geompy.MakeMultiRotation2DNbTimes(Shape, Dir, Point, NbTimes1, RadialStep, NbTimes2), geompy.MakeMultiRotation2DByStep(Shape, Dir, Point, AngleStep, NbTimes1, RadialStep, NbTimes2), which works in the same way, but the Axis is defined by direction and point.
The initial object
The result of a double multi-rotation
