Some algorithms of GEOM module return a list of shapes sorted in accordance with some criterion. The goal of this sorting is a possibility to obtain stable result regardless SALOME version being used.
The algorithm that provides such a possibility consists of the following steps:
For each shape a pair of point and number is associated. The point and number depend on the shape type:
| Shape Type | Point | Number |
| Vertex | Vertex isself | Orientation value converted to double |
| Edge, Wire | Center of mass | Total length of edges |
| Face, Shell | Center of mass | Total area of faces |
| Other | Center of mass | Total volume of solids |
Each point is converted to double using the following expression:
point.X() * 999.0 + point.Y() * 99.0 + point.Z() * 0.9
The shapes are sorted in ascending order. The shape comparison criterion is the following. Shape_1 is considered less then Shape_2 if:
Shape_1's double value obtained on the step 2 is less than the corresponding value of Shape_2.
Otherwise if they are equal with the confusion tolerance (1.e-7):
Shape_1's number obtained on the step 1 is less than the corresponding number of Shape_2.
Otherwise if they are equal with the confusion tolerance (1.e-7) and the shapes have either Face or more complex type:
Shape_1's squared diagonal of bounding box is less than the one of Shape_2.
Get the minimal and maximal values of X, Y and Z coordinates of bounding boxes for Shape_1 and Shape_2. Compute the following values for Shape_1 and Shape_2:
(aXmin+aXmax) * 999.0 + (aYmin+aYmax) * 99.0 + (aZmin+aZmax) * 0.9
Shape_1 is less than Shape_2 if this value for Shape_1 is less than the value for Shape_2.
This algorithm is used in the following geomBuilder methods:
- SubShapeAllSortedCentres
- SubShapeAllSortedCentresIDs
- SubShapeSortedCentres
- ExtractShapes
and as a part of some other algorithms where sorting is required.
