Loading...
Searching...
No Matches
Transparency
You can change the transparency of a shape in the range between 0% (absolutely opaque) and 100% (absolutely transparent and thus invisible) in the following dialog box.
or using a TUI Command: gg.setTransparency(ID, Value)
where
  • ID is an object ID (entry)
  • Value is a transparency value in range [0-1]; 0 means fully opaque, 1 means fully transparent
Examples:
Opaque
50% Transparent
Our TUI Scripts provide you with useful examples of Changing Display Parameters.
