from salome.kernel import salome
from inspect import getfile
from os.path import abspath, dirname, join
salome.salome_init_without_session()
from salome.kernel import GEOM
O = geompy.MakeVertex(0, 0, 0)
OX = geompy.MakeVectorDXDYDZ(1, 0, 0)
OY = geompy.MakeVectorDXDYDZ(0, 1, 0)
OZ = geompy.MakeVectorDXDYDZ(0, 0, 1)
Vertex_1 = geompy.MakeVertex(0, 0, 0)
Vertex_2 = geompy.MakeVertex(50, 100, 0)
Vertex_3 = geompy.MakeVertex(-10, 60, 0)
Vertex_4 = geompy.MakeVertex(0, 100, 0)
Vertex_5 = geompy.MakeVertex(-100, 100, 0)
Vertex_6 = geompy.MakeVertex(-100, 0, 0)
Vertex_7 = geompy.MakeVertex(-200, 0, 0)
Vertex_8 = geompy.MakeVertex(-200, 100, 0)
Line_1 = geompy.MakeLineTwoPnt(Vertex_1, Vertex_2)
Circle_1 = geompy.MakeCircle(Vertex_2, OZ, 50)
Ellipse_1 = geompy.MakeEllipse(Vertex_1, OZ, 200, 100, Line_1)
Arc_1 = geompy.MakeArc(Vertex_2, Vertex_3, Vertex_1)
Curve_1 = geompy.MakeCurveParametric("t", "50*sin(t)", "0", 0, 360, 30, GEOM.Interpolation, True)
Curve_2 = geompy.MakeCurveParametric("-t", "50*cos(t)", "t", 0, 360, 14, GEOM.Bezier, True)
Curve_5 = geompy.MakeInterpol([Vertex_1, Vertex_4, Vertex_5, Vertex_6, Vertex_7, Vertex_8], False, False)
Curve_7 = geompy.MakeBezier([Vertex_5, Vertex_6, Vertex_7, Vertex_8], True)
Curve_8 = geompy.MakeBezier([Vertex_5, Vertex_6, Vertex_1, Vertex_4], False)
props = geompy.KindOfShape(Line_1)
print("KindOfShape(Line_1): ", props)
props = geompy.KindOfShape(Circle_1)
print("KindOfShape(Circle_1): ", props)
props = geompy.KindOfShape(Ellipse_1)
print("KindOfShape(Ellipse_1): ", props)
props = geompy.KindOfShape(Arc_1)
print("KindOfShape(Arc_1): ", props)
props = geompy.KindOfShape(Curve_1)
print("KindOfShape(Curve_1): ", props)
props = geompy.KindOfShape(Curve_2)
print("KindOfShape(Curve_2): ", props)
props = geompy.KindOfShape(Curve_5)
print("KindOfShape(Curve_5): ", props)
props = geompy.KindOfShape(Curve_7)
print("KindOfShape(Curve_7): ", props)
props = geompy.KindOfShape(Curve_8)
print("KindOfShape(Curve_8): ", props)
import sys
salome.salome_init()
from salome.kernel import salome_notebook
notebook = salome_notebook.NoteBook()
import math
from salome.kernel import SALOMEDS
def approximatelyEqual(a, b, epsilon = 1e-5):
return abs(a - b) <= ((abs(b) if (abs(a) < abs(b)) else abs(a)) * epsilon)
def assertShapeKindEquals(iShapeInfo, iKind):
assert (len(iShapeInfo) > 0), "Yielded data array is empty."
assert (iShapeInfo[0] == iKind), f"Expected shape kind is {iKind}, but yielded kind is {iShapeInfo[0]}."
def assertConePropsEqual(iShapeName, iShapeInfo, iExpectedShapeInfo):
assertShapeKindEquals(iShapeInfo, geompy.kind.CONE2D)
assert (len(iShapeInfo) == len(iExpectedShapeInfo)), f"{iShapeName}: Yielded data array is of unexpected length."
for idx in range(1, len(iShapeInfo)):
assert (approximatelyEqual(iShapeInfo[idx], iExpectedShapeInfo[idx])), f"{iShapeName}: Yielded data array element is not equal to the expected value."
def assertConeInfoEquals(iFace, iExpectedShapeInfo, iAddRestoredConeToStudy = False):
ShapeInfo = geompy.KindOfShape(iFace)
print("ShapeInfo of " + iFace.GetName() + " = ", end = "")
print(ShapeInfo, ', ')
assertConePropsEqual(iFace.GetName(), ShapeInfo, iExpectedShapeInfo)
if (iAddRestoredConeToStudy):
BottomLidCenter = geompy.MakeVertex(ShapeInfo[1], ShapeInfo[2], ShapeInfo[3])
AxisAuxPnt = geompy.MakeVertex(ShapeInfo[1] + ShapeInfo[4], ShapeInfo[2] + ShapeInfo[5], ShapeInfo[3] + ShapeInfo[6])
Axis = geompy.MakeVector(BottomLidCenter, AxisAuxPnt)
R1 = ShapeInfo[7]
R2 = ShapeInfo[8]
H = ShapeInfo[9]
RestoredCone = geompy.MakeCone(BottomLidCenter, Axis, R1, R2, H)
geompy.addToStudy(RestoredCone, iFace.GetName() + '__RestoredCone')
def partitionConeAndAssertShapeInfosEqual(iCone, iPartitioningShape, iExpectedConeFragmentShapeInfos, iAddResultsToStudy):
PartitionedCone = geompy.MakePartition([iCone], [iPartitioningShape], [], [], geompy.ShapeType["FACE"], 0, [], 0)
if (iAddResultsToStudy):
geompy.addToStudy(PartitionedCone, "Partitioned" + iCone.GetName())
ConeFragments = geompy.ExtractShapes(PartitionedCone, geompy.ShapeType["FACE"], True)
ConeFragmentsIdxs = iExpectedConeFragmentShapeInfos.keys()
for ConeFragmentIdx in ConeFragmentsIdxs:
assert (ConeFragmentIdx < len(ConeFragments)), f"Num of faces, {iCone.GetName()} is partitioned into, <= {ConeFragmentIdx} (zero-based index)."
ConeFragment = ConeFragments[ConeFragmentIdx]
ConeFragmentName = f"Partitioned{iCone.GetName()}_Face_{ConeFragmentIdx+1}"
geompy.addToStudyInFather(PartitionedCone, ConeFragment, ConeFragmentName)
else:
ConeFragment.SetName(ConeFragmentName)
assertConeInfoEquals(ConeFragment, iExpectedConeFragmentShapeInfos[ConeFragmentIdx], iAddResultsToStudy)
OriginalConeBaseCenter = geompy.MakeVertex(100, 130, -60)
OriginalConeAxisAuxPnt = geompy.MakeVertex(100, 230, 40)
OriginalConeAxis = geompy.MakeVector(OriginalConeBaseCenter, OriginalConeAxisAuxPnt)
OriginalCone = geompy.MakeCone(OriginalConeBaseCenter, OriginalConeAxis, 100, 50, 300)
PrismSubstrateCenter = geompy.MakeVertex(100, 1000, 50)
PrismDirAuxPnt = geompy.MakeVertex(100, 950, 50)
PrismDir = geompy.MakeVector(PrismSubstrateCenter, PrismDirAuxPnt)
PrismSubstrate = geompy.MakeDiskPntVecR(PrismSubstrateCenter, PrismDir, 100)
sk = geompy.Sketcher2D()
sk.addPoint(0.395986, 43.346713)
sk.addSegmentAbsolute(66.321537, 41.733575)
sk.addSegmentAbsolute(80.619408, -2.852314)
sk.addSegmentAbsolute(67.641539, -38.565150)
sk.addSegmentAbsolute(22.193602, -56.632163)
sk.addSegmentAbsolute(-19.060136, -51.084351)
sk.addSegmentAbsolute(-60.823572, 34.825751)
sk.addSegmentAbsolute(-13.047004, 55.727527)
sk.close()
PrismBase = sk.wire(PrismSubstrate)
Prism = geompy.MakePrismVecH(PrismBase, PrismDir, 1400)
geompy.addToStudy( OriginalConeBaseCenter, 'OriginalConeBaseCenter' )
geompy.addToStudy( OriginalConeAxisAuxPnt, 'OriginalConeAxisAuxPnt' )
geompy.addToStudy( OriginalConeAxis, 'OriginalConeAxis' )
geompy.addToStudy( OriginalCone, 'OriginalCone' )
geompy.addToStudy( PrismSubstrateCenter, 'PrismSubstrateCenter' )
geompy.addToStudy( PrismDirAuxPnt, 'PrismDirAuxPnt' )
geompy.addToStudy( PrismDir, 'PrismDir' )
geompy.addToStudy( PrismSubstrate, 'PrismSubstrate' )
geompy.addToStudy( PrismBase, 'PrismBase' )
geompy.addToStudy( Prism, 'Prism' )
ExpectedOriginalConeFragmentsShapeInfos = {
3: ["CONE2D", 100.0, 215.76160602318674, 25.761606023186744, 0.0, 0.7071067811865475, 0.7071067811865475, 79.7857956051852, 54.62305376134459, 150.9764510630437],
5: ["CONE2D", 100.0, 129.99999999999753, -60.000000000002466, 0.0, 0.7071067811865475, 0.7071067811865475, 100.00000000000058, 69.82277418813575, 181.06335487118898],
11: ["CONE2D", 100.0, 216.57653245407857, 26.57653245407856, 0.0, 0.7071067811865475, 0.7071067811865475, 79.59371560336794, 52.95933239773038, 159.80629923382543]
partitionConeAndAssertShapeInfosEqual(OriginalCone, Prism, ExpectedOriginalConeFragmentsShapeInfos, True)
ScaledCone = geompy.MakeScaleTransform(OriginalCone, OriginalConeAxisAuxPnt, 2)
ScaledCone.SetName('ScaledCone')
ExpectedScaledConeFragmentsShapeInfos = {
4: ["CONE2D", 100.0, 29.9999999999999, -160.00000000000009, 0.0, 0.7071067811865475, 0.7071067811865475, 200.00000000000003, 162.64508449690112, 224.1294930185934],
6: ["CONE2D", 100.0, 262.09898500769475, 72.09898500769472, 0.0, 0.7071067811865475, 0.7071067811865475, 145.2937445981814, 120.13428858458612, 150.95673608157182],
12: ["CONE2D", 100.0, 262.8999708414969, 72.8999708414969, 0.0, 0.7071067811865475, 0.7071067811865475, 145.10495042660943, 117.46838914559419, 165.8193676860916]
partitionConeAndAssertShapeInfosEqual(ScaledCone, Prism, ExpectedScaledConeFragmentsShapeInfos, False)
PntMirroredCone = geompy.MakeMirrorByPoint(OriginalCone, OriginalConeAxisAuxPnt)
PntMirroredCone.SetName('PntMirroredCone')
ExpectedPntMirroredConeFragmentsShapeInfos = {
2: ["CONE2D", 100.0, 229.8712015945071, 39.87120159450711, -0.0, -0.7071067811865475, -0.7071067811865475, 76.39941588513841, 51.25530645152799, 150.8646566016625],
7: ["CONE2D", 100.0, 330.0, 140.0, -0.0, -0.7071067811865475, -0.7071067811865475, 100.0, 71.73019727352477, 169.61881635885143],
10: ["CONE2D", 100.0, 249.15532313133338, 59.15532313133339, -0.0, -0.7071067811865475, -0.7071067811865475, 80.9447269211102, 51.428754043115056, 177.09583726797095]
partitionConeAndAssertShapeInfosEqual(PntMirroredCone, Prism, ExpectedPntMirroredConeFragmentsShapeInfos, False)
if salome.sg.hasDesktop():
salome.sg.updateObjBrowser()
