Loading...
Searching...
No Matches
Repairing Operations
Shape Processing
# Shape Processing
from salome.kernel import salome
salome.salome_init_without_session()
from salome.kernel import GEOM
geompy = geomBuilder.New()
gg = salome.ImportComponentGUI("GEOM")
# create vertices, an edge, an arc, a wire, a face and a prism
p1 = geompy.MakeVertex(0,0,0)
p2 = geompy.MakeVertex(200,0,0)
p3 = geompy.MakeVertex(100,150,0)
edge = geompy.MakeEdge(p1,p2)
arc = geompy.MakeArc(p1,p3,p2)
wire = geompy.MakeWire([edge,arc])
face = geompy.MakeFace(wire, 1)
theShape = geompy.MakePrismVecH(face, edge, 130)
# check the shape at the beginning
print("Before ProcessShape:")
isValid = geompy.CheckShape(theShape, True)
if isValid == 0:
print("The shape is not valid")
else:
print("The shape seems to be valid")
# process the Shape
Operators = ["FixShape"]
Parameters = ["FixShape.Tolerance3d"]
Values = ["1e-7"]
PS = geompy.ProcessShape(theShape, Operators, Parameters, Values)
# check the shape at the end
print("After ProcessShape:")
isValid = geompy.CheckShape(PS, True)
if isValid == 0:
raise RuntimeError("It seems, that the ProcessShape() has failed")
else:
# add in the study and display
Id_Shape = geompy.addToStudy(theShape, "Invalid Shape")
Id_PS = geompy.addToStudy(PS, "Processed Shape")
gg.createAndDisplayGO(Id_Shape)
gg.setDisplayMode(Id_Shape,1)
gg.createAndDisplayGO(Id_PS)
gg.setDisplayMode(Id_PS,1)
New(instance=None)
Download this script
Suppress Faces
# Suppress Faces
# create a box
box = geompy.MakeBoxDXDYDZ(200, 200, 200)
# The list of IDs (IDList) for suppress faces
sup_faces = []
sup_faces = geompy.SubShapeAllSortedCentres(box, geompy.ShapeType["FACE"])
# get indices of the sub-shape
f1_id = geompy.GetSubShapeID(box, sup_faces[3])
# remove faces from the given object (shape)
result = geompy.SuppressFaces(box, [f1_id])
# add objects in the study
id_box = geompy.addToStudy(box, "Box")
id_result = geompy.addToStudy(result, "Result")
# display the results
gg.createAndDisplayGO(id_box)
gg.setDisplayMode(id_box,1)
gg.createAndDisplayGO(id_result)
gg.setDisplayMode(id_result,1)
Close Contour
# Close Contour
# create vertices and vectors
p0 = geompy.MakeVertex( 0., 0., 0.)
px = geompy.MakeVertex(100., 0., 0.)
py = geompy.MakeVertex( 0., 100., 0.)
py1 = geompy.MakeVertex( 0., 140., 0.)
pz = geompy.MakeVertex( 0., 0., 100.)
vxy = geompy.MakeVector(px, py)
# create an arc
arc = geompy.MakeArc(py1, pz, px)
# create a wire
wire = geompy.MakeWire([vxy, arc])
# close an open wire by creation of an edge between ends
wire_close = geompy.CloseContour(wire, [1], 0)
id_wire = geompy.addToStudy(wire, "Wire")
id_wire_close = geompy.addToStudy(wire_close, "Wire close")
gg.createAndDisplayGO(id_wire)
gg.createAndDisplayGO(id_wire_close)
Suppress Internal Wires
# Suppress Internal Wires
# create a vertex and a vector
p1 = geompy.MakeVertex(55, 65, 50)
p2 = geompy.MakeVertex(55, 0, 50)
v = geompy.MakeVector(p1, p2)
# create a cylinder
height = 100
radius1 = 40
cylinder = geompy.MakeCylinder(p1, v, radius1, height)
# create a box
box = geompy.MakeBoxDXDYDZ(100, 100, 100)
# make a cut
cut = geompy.MakeCut(box, cylinder)
# suppress all internal wires
result = geompy.SuppressInternalWires(cut, [])
id_cut = geompy.addToStudy(cut, "Cut")
gg.createAndDisplayGO(id_cut)
gg.setDisplayMode(id_cut,1)
Suppress Holes
# Suppress Holes
p1 = geompy.MakeVertex(35, 35, 0)
p2 = geompy.MakeVertex(35, 35, 50)
# create a cylinder
height = 20
radius1 = 20
# create a cone
cone = geompy.MakeCone(p1, v, 70, 0, 80)
# make a cut
cut = geompy.MakeCut(cone, cylinder)
# get faces as sub-shapes
faces = geompy.SubShapeAllSortedCentres(cut, geompy.ShapeType["FACE"])
f_2 = geompy.GetSubShapeID(cut, faces[2])
# remove one face from the shape
cut_without_f_2 = geompy.SuppressFaces(cut, [f_2])
# get edges as sub-shapes
edges = geompy.SubShapeAllSortedCentres(faces[2], geompy.ShapeType["EDGE"])
edge = geompy.GetInPlace(cut_without_f_2, edges[0], True)
e_2 = geompy.GetSubShapeID(cut_without_f_2, edge)
# suppress a hole using the selected edge
result = geompy.SuppressHoles(cut_without_f_2, [e_2])
id_cut_without_f_2 = geompy.addToStudy(cut_without_f_2, "Cut without f_2")
gg.createAndDisplayGO(id_cut_without_f_2)
gg.setDisplayMode(id_cut_without_f_2,1)
Sewing
# Sewing
import math
# create base points
py = geompy.MakeVertex(0., 100., 0.)
pz = geompy.MakeVertex(0., 0., 100.)
# create base geometry 2D
vector = geompy.MakeVector(px, py)
arc = geompy.MakeArc(py, pz, px)
# create base objects
angle = 45. * math.pi / 180
WantPlanarFace = True
wire = geompy.MakeWire([vector, arc])
face = geompy.MakeFace(wire, WantPlanarFace)
face_rot = geompy.MakeRotation(face, vector, angle)
# make sewing
precision = 0.00001
sewing = geompy.MakeSewing([face, face_rot], precision)
id_face = geompy.addToStudy(face, "Face")
id_face_rot = geompy.addToStudy(face_rot, "Face rotation")
id_sewing = geompy.addToStudy(sewing, "Sewing")
gg.createAndDisplayGO(id_face)
gg.setDisplayMode(id_face,1)
gg.createAndDisplayGO(id_face_rot)
gg.setDisplayMode(id_face_rot,1)
gg.createAndDisplayGO(id_sewing)
gg.setDisplayMode(id_sewing,1)
# Example 2: make a shell of a multiply translated face
quad = geompy.MakeFaceHW( 10, 20, 1 )
quadCompound = geompy.MakeMultiTranslation1D( quad, geompy.MakeVectorDXDYDZ(1,0,0), 10, 3)
shell = geompy.Sew( quadCompound, 1e-6 )
id_shell = geompy.addToStudy( shell, "3 quads shell")
gg.createAndDisplayGO(id_shell)
Glue Faces
# Glue Faces
# create boxes
box1 = geompy.MakeBox(0,0,0,100,50,100)
box2 = geompy.MakeBox(100,0,0,250,50,100)
# make compound
compound = geompy.MakeCompound([box1, box2])
# glue compound's faces
tolerance = 1e-5
glue = geompy.MakeGlueFaces(compound, tolerance)
# add objects in study
id_box1 = geompy.addToStudy(box1, "Box1")
id_box2 = geompy.addToStudy(box2, "Box2")
id_compound = geompy.addToStudy(compound, "Compound")
id_glue = geompy.addToStudy(glue, "Glue faces")
# display results
gg.createAndDisplayGO(id_box1)
gg.setDisplayMode(id_box1,1)
gg.createAndDisplayGO(id_box2)
gg.setDisplayMode(id_box2,1)
gg.createAndDisplayGO(id_compound)
gg.setDisplayMode(id_compound,1)
gg.createAndDisplayGO(id_glue)
gg.setDisplayMode(id_glue,1)
Glue Edges
# Glue Edges
# create boxes
# make compound
# glue all compound's edges
tolerance = 1e-5
glue1 = geompy.MakeGlueEdges(compound, tolerance)
# glue some compound's edges
list_edges = geompy.GetGlueEdges(compound, tolerance)
glue2 = geompy.MakeGlueEdgesByList(compound, tolerance, [list_edges[0], list_edges[2]])
geompy.addToStudy(glue1, "Glue all edges")
geompy.addToStudy(glue2, "Glue two edges")
if salome.sg.hasDesktop():
salome.sg.updateObjBrowser()
Limit Tolerance
# Limit Tolerance
salome.salome_init()
# import initial topology with bad tolerances (more than 1e-07)
shape1 = geompy.ImportBREP("my_shape_1.brep")
shape2 = geompy.ImportBREP("my_shape_2.brep")
geompy.addToStudy(shape1, "Shape 1")
geompy.addToStudy(shape2, "Shape 2")
# perform partition
try:
part = geompy.MakePartition([shape1, shape2])
except:
# limit tolerance
tolerance = 1e-07
shape1_lt = geompy.LimitTolerance(shape1, tolerance, True)
shape2_lt = geompy.LimitTolerance(shape2, tolerance, False)
# process shape
good_shape1 = geompy.ProcessShape(shape1_lt, ["FixShape"], ["FixShape.Tolerance3d"], ["1e-7"])
good_shape2 = geompy.ProcessShape(shape2_lt, ["FixShape"], ["FixShape.Tolerance3d"], ["1e-7"])
geompy.addToStudy(good_shape1, "Shape 1 corrected")
geompy.addToStudy(good_shape2, "Shape 2 corrected")
# perform partition on corrected shapes
part = geompy.MakePartition([good_shape1, good_shape2])
pass
geompy.addToStudy(part, "Partition")
Add Point on Edge
# Add Point on Edge
# Variant 1: using DivideEdge()
# create vertices
p1 = geompy.MakeVertex(0,0,50)
p2 = geompy.MakeVertex(60,0,50)
# make an edge
edge = geompy.MakeEdge(p1, p2) #geompy.GetSubShape(box, edge_ind)
# divide an edge
divide = geompy.DivideEdge(edge, -1, 0.5, 0)
id_edge = geompy.addToStudy(edge, "Edge")
edge_points = geompy.SubShapeAllSortedCentres(edge, geompy.ShapeType["VERTEX"])
for point in edge_points:
geompy.addToStudyInFather(edge, point, "Edge's point")
id_divide = geompy.addToStudy(divide, "Divided edge")
edge_points = geompy.SubShapeAllSortedCentres(divide, geompy.ShapeType["VERTEX"])
geompy.addToStudyInFather(divide, point, "Edge's point after divide")
# Variant 2: using DivideEdgeByPoint()
box = geompy.MakeBox(0,0,0, 10,10,10, theName="box")
p1 = geompy.MakeVertex( 3, -2, 1, theName="point 1 to project" )
p2 = geompy.MakeVertex( 7, -2, 1, theName="point 2 to project" )
edge = geompy.GetEdgeNearPoint( box, p1, theName="edge to split")
div = geompy.DivideEdgeByPoint( box, edge, [p1, p2], theName="box (edge divided)")
Fuse Collinear Edges within a Wire
# Fuse Collinear Edges within a Wire
# create vertices
p1 = geompy.MakeVertex(0, 0, 0)
p2 = geompy.MakeVertex(70, 0, 0)
p3 = geompy.MakeVertex(70, 50, 0)
p4 = geompy.MakeVertex(70, 80, 0)
p5 = geompy.MakeVertex(50, 80, 0)
p6 = geompy.MakeVertex(20, 80, 0)
p7 = geompy.MakeVertex(0, 80, 0)
p8 = geompy.MakeVertex(0, 30, 0)
points = [p1, p2, p3, p4, p5, p6, p7, p8]
# make a wire
wire_1 = geompy.MakePolyline(points, True)
# suppress some vertices in the wire
wire_2 = geompy.FuseCollinearEdgesWithinWire(wire_1, [p3])
wire_3 = geompy.FuseCollinearEdgesWithinWire(wire_1, [p5, p6])
# suppress all suitable vertices in the wire
wire_4 = geompy.FuseCollinearEdgesWithinWire(wire_1, [])
wires = [wire_1, wire_2, wire_3, wire_4]
ii = 1
for point in points:
geompy.addToStudy(point, "p%d"%ii)
ii = ii + 1
pass
ii = 1
for wire in wires:
geompy.addToStudy(wire, "wire_%d"%ii)
wire_points = geompy.SubShapeAllSortedCentres(wire, geompy.ShapeType["VERTEX"])
jj = 1
for point in wire_points:
geompy.addToStudyInFather(wire, point, "point_%d"%jj)
jj = jj + 1
pass
ii = ii + 1
pass
Remove internal(shared) faces
# Remove internal(shared) faces from a compound
# create solids with some coincident faces
Box_1 = geompy.MakeBoxDXDYDZ(200, 200, 200)
Translation_1 = geompy.MakeTranslation(Box_1, 200, 0, 0)
Translation_2 = geompy.MakeTranslation(Box_1, 200, 200, 0)
geompy.addToStudy(Box_1, 'Box_1')
geompy.addToStudy(Translation_1, 'Translation_1')
geompy.addToStudy(Translation_2, 'Translation_2')
# partition three solids to obtain shared faces
Partition_1 = geompy.MakePartition([Box_1, Translation_1, Translation_2])
geompy.addToStudy(Partition_1, 'Partition_1')
# remove shared faces to obtain one solid instead of three
Joined_1 = geompy.RemoveInternalFaces(Partition_1)
geompy.addToStudy(Joined_1, 'Joined_1')
