BlocksGUI_ExplodeDlg.h
24// File : BlocksGUI_ExplodeDlg.h
25// Author : Julia DOROVSKIKH, Open CASCADE S.A.S. (julia.dorovskikh@opencascade.com)
26//
27#ifndef BLOCKSGUI_EXPLODEDLG_H
28#define BLOCKSGUI_EXPLODEDLG_H
30#include <GEOMBase_Skeleton.h>
31
33
34//=================================================================================
35// class : BlocksGUI_ExplodeDlg
36// purpose :
37//=================================================================================
39{
40 Q_OBJECT
41
42public:
45
46protected:
47 // redefined from GEOMBase_Helper
48 virtual GEOM::GEOM_IOperations_ptr createOperation();
49 virtual bool isValid( QString& );
50 virtual bool execute( ObjectList& );
51 virtual GEOM::GEOM_Object_ptr getFather( GEOM::GEOM_Object_ptr );
52 virtual QList<GEOM::GeomObjPtr> getSourceObjects();
53
54 virtual QString getNewObjectName (int CurrObj = -1) const;
55
56private:
57 void Init();
58 void enterEvent( QEvent* );
59
60 void activateSelection();
61
62 void updateButtonState();
63 bool isAllSubShapes() const;
64 int shapeType() const;
65
66 void clearTemporary();
67
68private:
70
71 CORBA::Long myNbBlocks;
72 GEOM::GEOM_Object_var myObject;
73
75
77
78private slots:
79 void ClickOnOk();
80 bool ClickOnApply();
81 void ActivateThisDialog();
82 void ConstructorsClicked( int );
83
86
87 void SubShapeToggled();
88
90};
91
92#endif // BLOCKSGUI_EXPLODEDLG_H
Definition: BlocksGUI_ExplodeDlg.h:39
void ConstructorsClicked(int)
Definition: BlocksGUI_ExplodeDlg.cxx:135
Definition: BlocksGUI_ExplodeDlg.cxx:361
BlocksGUI_ExplodeDlg(GeometryGUI *, QWidget *)
Definition: BlocksGUI_ExplodeDlg.cxx:48
void enterEvent(QEvent *)
Definition: BlocksGUI_ExplodeDlg.cxx:262
Definition: BlocksGUI_ExplodeDlg.cxx:294
void ValueChangedInSpinBox()
Definition: BlocksGUI_ExplodeDlg.cxx:272
Definition: BlocksGUI_ExplodeDlg.cxx:489
ObjectList myTmpObjs
Definition: BlocksGUI_ExplodeDlg.h:74
Definition: BlocksGUI_ExplodeDlg.cxx:401
void SetEditCurrentArgument()
Definition: BlocksGUI_ExplodeDlg.cxx:232
bool ClickOnApply()
Definition: BlocksGUI_ExplodeDlg.cxx:175
int myConstructorId
Definition: BlocksGUI_ExplodeDlg.h:69
DlgRef_1Sel2Spin1View1Check * myGrp1
Definition: BlocksGUI_ExplodeDlg.h:76
void ClickOnOk()
Definition: BlocksGUI_ExplodeDlg.cxx:164
virtual QString getNewObjectName(int CurrObj=-1) const
Definition: BlocksGUI_ExplodeDlg.cxx:512
Definition: BlocksGUI_ExplodeDlg.cxx:370
virtual GEOM::GEOM_Object_ptr getFather(GEOM::GEOM_Object_ptr)
Definition: BlocksGUI_ExplodeDlg.cxx:503
Definition: BlocksGUI_ExplodeDlg.cxx:285
Definition: BlocksGUI_ExplodeDlg.h:72
Definition: BlocksGUI_ExplodeDlg.cxx:249
~BlocksGUI_ExplodeDlg()
Definition: BlocksGUI_ExplodeDlg.cxx:90
Definition: BlocksGUI_ExplodeDlg.cxx:352
Definition: BlocksGUI_ExplodeDlg.cxx:521
Definition: BlocksGUI_ExplodeDlg.h:71
Definition: BlocksGUI_ExplodeDlg.cxx:319
void SelectionIntoArgument()
Definition: BlocksGUI_ExplodeDlg.cxx:204
void Init()
Definition: BlocksGUI_ExplodeDlg.cxx:100
Definition: DlgRef.h:189
Definition: GeometryGUI.h:74
