BooleanGUI_Dialog.h
24// File : BooleanGUI_Dialog.h
25// Author : Lucien PIGNOLONI, Open CASCADE S.A.S.
26//
27#ifndef BOOLEANGUI_DIALOG_H
28#define BOOLEANGUI_DIALOG_H
30#include "GEOMBase_Skeleton.h"
31#include "GEOM_GenericObjPtr.h"
32
34class QLabel;
35class SalomeApp_DoubleSpinBox;
36
37//=================================================================================
38// class : BooleanGUI_Dialog
39// purpose :
40//=================================================================================
42{
43 Q_OBJECT
44
45public:
46 BooleanGUI_Dialog( const int, GeometryGUI*, QWidget* = 0,
47 bool = false, Qt::WindowFlags = 0 );
49
50protected:
51 // redefined from GEOMBase_Helper
52 virtual GEOM::GEOM_IOperations_ptr createOperation();
53 virtual bool isValid( QString& );
54 virtual bool execute( ObjectList& );
55 virtual void restoreSubShapes( SALOMEDS::SObject_ptr );
56 virtual void addSubshapesToStudy();
57 virtual QList<GEOM::GeomObjPtr> getSourceObjects();
58
59private:
60 void Init();
61 void enterEvent( QEvent* );
62 void reset();
63 void singleSelection();
64 void multipleSelection();
65
66private:
68
70 QList<GEOM::GeomObjPtr> myObjects;
71
73 QLabel* myFuzzyLbl;
74 SalomeApp_DoubleSpinBox* myFuzzyEdt;
75
76private slots:
77 void ClickOnOk();
78 bool ClickOnApply();
79 void UseFuzzyChanged(int state);
82 void ActivateThisDialog();
83};
84
85#endif // BOOLEANGUI_DIALOG_H
Definition: BooleanGUI_Dialog.h:42
Definition: BooleanGUI_Dialog.cxx:512
int myOperation
Definition: BooleanGUI_Dialog.h:67
Definition: BooleanGUI_Dialog.cxx:418
Definition: BooleanGUI_Dialog.cxx:523
SalomeApp_DoubleSpinBox * myFuzzyEdt
Definition: BooleanGUI_Dialog.h:74
Definition: BooleanGUI_Dialog.cxx:453
void enterEvent(QEvent *)
Definition: BooleanGUI_Dialog.cxx:408
QList< GEOM::GeomObjPtr > myObjects
Definition: BooleanGUI_Dialog.h:70
bool ClickOnApply()
Definition: BooleanGUI_Dialog.cxx:246
GEOM::GeomObjPtr myObject1
Definition: BooleanGUI_Dialog.h:69
void SelectionIntoArgument()
Definition: BooleanGUI_Dialog.cxx:327
void ClickOnOk()
Definition: BooleanGUI_Dialog.cxx:235
Definition: BooleanGUI_Dialog.cxx:308
QLabel * myFuzzyLbl
Definition: BooleanGUI_Dialog.h:73
Definition: BooleanGUI_Dialog.cxx:270
Definition: BooleanGUI_Dialog.cxx:345
Definition: BooleanGUI_Dialog.cxx:427
virtual void restoreSubShapes(SALOMEDS::SObject_ptr)
Definition: BooleanGUI_Dialog.cxx:497
Definition: BooleanGUI_Dialog.cxx:395
DlgRef_2Sel2Spin3Check * myGroup
Definition: BooleanGUI_Dialog.h:72
~BooleanGUI_Dialog()
Definition: BooleanGUI_Dialog.cxx:168
void Init()
Definition: BooleanGUI_Dialog.cxx:176
void SetEditCurrentArgument()
Definition: BooleanGUI_Dialog.cxx:360
BooleanGUI_Dialog(const int, GeometryGUI *, QWidget *=0, bool=false, Qt::WindowFlags=0)
Definition: BooleanGUI_Dialog.cxx:54
void reset()
Definition: BooleanGUI_Dialog.cxx:261
Definition: DlgRef.h:495
Definition: GeometryGUI.h:74
GenericObjPtr< GEOM::GEOM_Object > GeomObjPtr
Definition: GEOM_GenericObjPtr.h:218
