27#ifndef ENTITYGUI_SKETCHERDLG_H
28#define ENTITYGUI_SKETCHERDLG_H
40class SalomeApp_DoubleSpinBox;
56# define COORD_MIN -1e+15
57# define COORD_MAX +1e+15
58# define MAX_NUMBER 100000
59# define DBL_DIGITS_DISPLAY 16
78 void OnPointSelected( Qt::KeyboardModifiers,
const gp_Pnt&,
bool isStart =
true );
82 double,
double,
double = 0.1,
83 const char* quantity =
"length_precision" );
87 virtual bool isValid( QString& );
Definition: EntityGUI_Widgets.h:67
Definition: EntityGUI_Widgets.h:34
Definition: EntityGUI_Widgets.h:83
Definition: EntityGUI_Widgets.h:50
Definition: EntityGUI_Widgets.h:99
Definition: EntityGUI_Widgets.h:147
Definition: EntityGUI_Widgets.h:163
Definition: EntityGUI_Widgets.h:179
Definition: EntityGUI_Widgets.h:197
Definition: EntityGUI_Widgets.h:215
Definition: EntityGUI_Widgets.h:283
Definition: EntityGUI_SketcherDlg.h:67
QString myY2Str
Definition: EntityGUI_SketcherDlg.h:153
Standard_Real myRadius
Definition: EntityGUI_SketcherDlg.h:148
QString myXStr
Definition: EntityGUI_SketcherDlg.h:152
EntityGUI_2Spin * Group2Spin
Definition: EntityGUI_SketcherDlg.h:170
Standard_Real myYc
Definition: EntityGUI_SketcherDlg.h:147
EntityGUI_4Spin1Check * Group4Spin
Definition: EntityGUI_SketcherDlg.h:172
QComboBox * ComboBox1
Definition: EntityGUI_SketcherDlg.h:178
Standard_Real myXc
QString myYcStr
Definition: EntityGUI_SketcherDlg.h:154
void Init()
Definition: EntityGUI_SketcherDlg.cxx:444
int myCheckFlag
Definition: EntityGUI_SketcherDlg.h:195
void OnNextPoint()
Definition: EntityGUI_SketcherDlg.cxx:1789
QString myRadiusStr
Definition: EntityGUI_SketcherDlg.h:155
QString myX2Str
void ClickOnCancel()
Definition: EntityGUI_SketcherDlg.cxx:1125
TopAbs_ShapeEnum myNeedType
Definition: EntityGUI_SketcherDlg.h:197
SketchState
Definition: EntityGUI_SketcherDlg.h:200
@ NEXT_POINT
@ FIRST_POINT
virtual void addSubshapesToStudy()
Definition: EntityGUI_SketcherDlg.cxx:2865
void AddLocalCS(GEOM::GEOM_Object_var)
Definition: EntityGUI_SketcherDlg.cxx:2706
void DestClicked(int)
Definition: EntityGUI_SketcherDlg.cxx:656
QString myDYStr
void displayPntPreview(const double=0.0, const double=0.0, bool=true, bool=true)
Definition: EntityGUI_SketcherDlg.cxx:2550
int myConstructorId
Definition: EntityGUI_SketcherDlg.h:127
Standard_Real myLastY2
Definition: EntityGUI_SketcherDlg.h:150
bool myIsAllAdded
Definition: EntityGUI_SketcherDlg.h:133
Standard_Real myX1
Definition: EntityGUI_SketcherDlg.h:146
void setEnabledUndo(bool)
Definition: EntityGUI_SketcherDlg.cxx:1328
GEOM::GEOM_Object_var myGlobalCS
Definition: EntityGUI_SketcherDlg.h:191
void CheckBoxClicked(int)
Definition: EntityGUI_SketcherDlg.cxx:1113
EntityGUI_1Sel1Spin1Check * Group1Sel1Spin
Definition: EntityGUI_SketcherDlg.h:168
int mySketchState
Definition: EntityGUI_SketcherDlg.h:131
void LineEditReturnPressed()
Definition: EntityGUI_SketcherDlg.cxx:1583
QString myDXcStr
QGroupBox * GroupBox1
Definition: EntityGUI_SketcherDlg.h:177
DlgRef_4Spin * GroupRect
Definition: EntityGUI_SketcherDlg.h:173
int myConstructorPntId
Definition: EntityGUI_SketcherDlg.h:129
bool eventFilter(QObject *object, QEvent *event)
Definition: EntityGUI_SketcherDlg.cxx:404
virtual GEOM::GEOM_IOperations_ptr createOperation()
Definition: EntityGUI_SketcherDlg.cxx:2272
Standard_Real myY
Definition: EntityGUI_SketcherDlg.h:145
double myLineWidth
Definition: EntityGUI_SketcherDlg.h:188
void DeactivateActiveDialog()
Definition: EntityGUI_SketcherDlg.cxx:1613
EntityGUI_1Sel * Group1Sel
Definition: EntityGUI_SketcherDlg.h:166
Standard_Real myX
QString myXcStr
virtual void displayPreview(GEOM::GEOM_Object_ptr, const bool=false, const bool=false, const bool=true, const double=-1, const int=-1, const int=-1)
Definition: EntityGUI_SketcherDlg.cxx:2490
QList< GEOM::GEOM_Object_var > myWPlaneList
Definition: EntityGUI_SketcherDlg.h:193
int getPnt1ConstructorId() const
Definition: EntityGUI_SketcherDlg.cxx:2817
QString myDXStr
QStringList myUndoParameters
Definition: EntityGUI_SketcherDlg.h:143
QStringList myParameters
Definition: EntityGUI_SketcherDlg.h:142
QString myLastY1Str
Definition: EntityGUI_SketcherDlg.h:156
QString GetNewCommand(QString &)
Definition: EntityGUI_SketcherDlg.cxx:2118
EntityGUI_Dir1 * GroupD1
Definition: EntityGUI_SketcherDlg.h:163
gp_Ax3 GetActiveLocalCS()
Definition: EntityGUI_SketcherDlg.cxx:2839
void Dir2Clicked(int)
Definition: EntityGUI_SketcherDlg.cxx:908
QString myY1Str
QStringList myCommand
Definition: EntityGUI_SketcherDlg.h:139
int mySketchType
Definition: EntityGUI_SketcherDlg.h:130
void closeEvent(QCloseEvent *)
Definition: EntityGUI_SketcherDlg.cxx:1680
void setEnabledRedo(bool)
Definition: EntityGUI_SketcherDlg.cxx:1343
bool ClickOnApply()
Definition: EntityGUI_SketcherDlg.cxx:1191
Standard_Real myY2
void FindLocalCS()
Definition: EntityGUI_SketcherDlg.cxx:2733
gp_Ax3 WPlaneToLCS(GEOM::GEOM_Object_var)
Definition: EntityGUI_SketcherDlg.cxx:2785
void ClickOnUndo()
Definition: EntityGUI_SketcherDlg.cxx:1273
EntityGUI_SketcherDlg(GeometryGUI *, QWidget *=0, bool=false, Qt::WindowFlags=0, const double=-1)
Definition: EntityGUI_SketcherDlg.cxx:82
EntityGUI_Skeleton * MainWidget
Definition: EntityGUI_SketcherDlg.h:159
Standard_Real myLastY1
Definition: EntityGUI_SketcherDlg.h:149
EntityGUI_2Sel1Check * Group2Sel
Definition: EntityGUI_SketcherDlg.h:167
bool myIsApply
Definition: EntityGUI_SketcherDlg.h:134
void ClickOnEnd()
Definition: EntityGUI_SketcherDlg.cxx:1135
void TypeClicked(int)
Definition: EntityGUI_SketcherDlg.cxx:553
EntityGUI_1Spin * Group1Spin
Definition: EntityGUI_SketcherDlg.h:169
bool autoApply
Definition: EntityGUI_SketcherDlg.h:135
SketchType
Definition: EntityGUI_SketcherDlg.h:202
@ DIR_PER_LENGTH
Definition: EntityGUI_SketcherDlg.h:206
@ PT_REL_RADIUS
Definition: EntityGUI_SketcherDlg.h:203
@ DIR_TAN_X
Definition: EntityGUI_SketcherDlg.h:207
@ DIR_ANGLE_X
Definition: EntityGUI_SketcherDlg.h:205
@ PT_RELATIVE
@ DIR_ANGLE_LENGTH
@ DIR_PER_Y
@ DIR_ANGLE_Y
@ DIR_DXDY_X
Definition: EntityGUI_SketcherDlg.h:208
@ PT_ABS_CENTER
Definition: EntityGUI_SketcherDlg.h:204
@ PT_REL_CENTER
@ DIR_PER_X
@ DIR_DXDY_Y
@ PT_ABS_RADIUS
@ PT_SEL_CENTER
@ PT_ABS
@ DIR_TAN_LENGTH
@ DIR_DXDY_LENGTH
@ PT_SEL
@ PT_SEL_RADIUS
@ DIR_TAN_Y
Standard_Real myLength
void enterEvent(QEvent *)
Definition: EntityGUI_SketcherDlg.cxx:1669
QString myAngleStr
QString myYStr
EntityGUI_Point * GroupPt2
Definition: EntityGUI_SketcherDlg.h:162
void ClickOnRedo()
Definition: EntityGUI_SketcherDlg.cxx:1304
bool acceptMouseEvent() const
Definition: EntityGUI_SketcherDlg.cxx:2628
Standard_Real myAngle
void initSpinBox(SalomeApp_DoubleSpinBox *, double, double, double=0.1, const char *quantity="length_precision")
Definition: EntityGUI_SketcherDlg.cxx:2657
void ActivateLocalCS()
Definition: EntityGUI_SketcherDlg.cxx:2855
QString myLastX2Str
Definition: EntityGUI_SketcherDlg.h:157
QLineEdit * WPlaneLineEdit
Definition: EntityGUI_SketcherDlg.h:182
GEOM::GEOM_Object_var myWPlane
Definition: EntityGUI_SketcherDlg.h:192
void PointClicked(int)
Definition: EntityGUI_SketcherDlg.cxx:695
Standard_Real myDYc
void SetDoubleSpinBoxStep(double)
Definition: EntityGUI_SketcherDlg.cxx:2684
EntityGUI_3Spin1Check * Group3Spin
Definition: EntityGUI_SketcherDlg.h:171
Standard_Real myDX
void ClickOnHelp()
Definition: EntityGUI_SketcherDlg.cxx:1249
GeometryGUI * myGeometryGUI
Definition: EntityGUI_SketcherDlg.h:184
void SelectionIntoArgument()
Definition: EntityGUI_SketcherDlg.cxx:1358
QStringList myUndoCommand
Definition: EntityGUI_SketcherDlg.h:140
EntityGUI_Dir2 * GroupD2
Definition: EntityGUI_SketcherDlg.h:164
void InitClick()
Definition: EntityGUI_SketcherDlg.cxx:530
Definition: EntityGUI_SketcherDlg.h:161
QString myLastY2Str
QPushButton * planeButton
Definition: EntityGUI_SketcherDlg.h:179
QString myLastX1Str
QString myX1Str
void ActivateThisDialog()
Definition: EntityGUI_SketcherDlg.cxx:1628
QString myLengthStr
Standard_Real myDY
int myConstructorDirId
Definition: EntityGUI_SketcherDlg.h:128
Definition: EntityGUI_SketcherDlg.cxx:2281
void OnFirstPoint()
Definition: EntityGUI_SketcherDlg.cxx:1778
int getPnt2ConstructorId() const
Definition: EntityGUI_SketcherDlg.cxx:2828
Standard_Real myLastX2
Definition: EntityGUI_SketcherDlg.cxx:2318
Standard_Real myLastX1
bool createShapes(GEOM::GEOM_Object_ptr, TopoDS_Shape &, TopoDS_Shape &)
Definition: EntityGUI_SketcherDlg.cxx:2585
Standard_Real myX2
void OnPointSelected(Qt::KeyboardModifiers, const gp_Pnt &, bool isStart=true)
Definition: EntityGUI_SketcherDlg.cxx:1693
QString myHelpFileName
Definition: EntityGUI_SketcherDlg.h:186
void RectClicked()
Definition: EntityGUI_SketcherDlg.cxx:627
QString myDYcStr
Standard_Real myDXc
QList< gp_Ax3 > myLCSList
Definition: EntityGUI_SketcherDlg.h:190
QPushButton * selButton
Definition: EntityGUI_SketcherDlg.h:180
Standard_Real myY1
void keyPressEvent(QKeyEvent *)
Definition: EntityGUI_SketcherDlg.cxx:2641
void Dir1Clicked(int)
Definition: EntityGUI_SketcherDlg.cxx:890
void ValueChangedInSpinBox(double)
Definition: EntityGUI_SketcherDlg.cxx:1800
QLineEdit * myEditCurrentArgument
Definition: EntityGUI_SketcherDlg.h:137
void SetEditCurrentArgument()
Definition: EntityGUI_SketcherDlg.cxx:1541
QLabel * myErrLabel
Definition: EntityGUI_SketcherDlg.h:175
~EntityGUI_SketcherDlg()
Definition: EntityGUI_SketcherDlg.cxx:391
void Point2Clicked(int)
Definition: EntityGUI_SketcherDlg.cxx:714
Definition: GEOMBase_Helper.h:62
Definition: GeometryGUI.h:74
