GEOMImpl_IPlane.hxx
23//NOTE: This is an interface to a function for the vector creation.
24//
25#include "GEOM_Function.hxx"
26
27#define PLN_ARG_SIZE 1
28
29#define PLN_ARG_PNT1 2
30#define PLN_ARG_PNT2 3
31#define PLN_ARG_PNT3 4
32
33#define PLN_ARG_VEC 5
34
35#define PLN_ARG_REF 6
36
37#define PLN_ARG_PARAM_U 7
38
39#define PLN_ARG_PARAM_V 8
40
41#define PLN_ARG_VEC1 9
42#define PLN_ARG_VEC2 10
43
44#define PLN_ARG_ORIENT 11
45
46#define PLN_ARG_LCS 12
47
49{
50 public:
51
52 GEOMImpl_IPlane(Handle(GEOM_Function) theFunction): _func(theFunction) {}
53
54 void SetSize(double theSize) { _func->SetReal(PLN_ARG_SIZE, theSize); }
55
56 double GetSize() { return _func->GetReal(PLN_ARG_SIZE); }
57
58 void SetOrientation(double theOrientation) { _func->SetReal(PLN_ARG_ORIENT, theOrientation); }
59
60 double GetOrientation() { return _func->GetReal(PLN_ARG_ORIENT); }
61
62 void SetPoint (Handle(GEOM_Function) theRef) { _func->SetReference(PLN_ARG_PNT1, theRef); }
63 void SetVector(Handle(GEOM_Function) theRef) { _func->SetReference(PLN_ARG_VEC , theRef); }
64 void SetVector1(Handle(GEOM_Function) theRef) { _func->SetReference(PLN_ARG_VEC1 , theRef); }
65 void SetVector2(Handle(GEOM_Function) theRef) { _func->SetReference(PLN_ARG_VEC2 , theRef); }
66
67 void SetFace (Handle(GEOM_Function) theRef) { _func->SetReference(PLN_ARG_REF , theRef); }
68 void SetLCS (Handle(GEOM_Function) theRef) { _func->SetReference(PLN_ARG_LCS , theRef); }
69
70 void SetPoint1(Handle(GEOM_Function) theRef) { _func->SetReference(PLN_ARG_PNT1, theRef); }
71 void SetPoint2(Handle(GEOM_Function) theRef) { _func->SetReference(PLN_ARG_PNT2, theRef); }
72 void SetPoint3(Handle(GEOM_Function) theRef) { _func->SetReference(PLN_ARG_PNT3, theRef); }
73
74 Handle(GEOM_Function) GetPoint () { return _func->GetReference(PLN_ARG_PNT1); }
75 Handle(GEOM_Function) GetVector() { return _func->GetReference(PLN_ARG_VEC ); }
76 Handle(GEOM_Function) GetVector1() { return _func->GetReference(PLN_ARG_VEC1 ); }
77 Handle(GEOM_Function) GetVector2() { return _func->GetReference(PLN_ARG_VEC2 ); }
78
79 Handle(GEOM_Function) GetFace () { return _func->GetReference(PLN_ARG_REF ); }
80 Handle(GEOM_Function) GetLCS () { return _func->GetReference(PLN_ARG_LCS ); }
81
82 Handle(GEOM_Function) GetPoint1() { return _func->GetReference(PLN_ARG_PNT1); }
83 Handle(GEOM_Function) GetPoint2() { return _func->GetReference(PLN_ARG_PNT2); }
84 Handle(GEOM_Function) GetPoint3() { return _func->GetReference(PLN_ARG_PNT3); }
85
86 void SetParameterU(double theParamU) { _func->SetReal(PLN_ARG_PARAM_U, theParamU); }
87 double GetParameterU() { return _func->GetReal(PLN_ARG_PARAM_U); }
88
89 void SetParameterV(double theParamV) { _func->SetReal(PLN_ARG_PARAM_V, theParamV); }
90 double GetParameterV() { return _func->GetReal(PLN_ARG_PARAM_V); }
91
92 private:
93
94 Handle(GEOM_Function) _func;
95};
#define PLN_ARG_VEC
Definition: GEOMImpl_IPlane.hxx:33
Definition: GEOMImpl_IPlane.hxx:39
Definition: GEOMImpl_IPlane.hxx:30
Definition: GEOMImpl_IPlane.hxx:44
Definition: GEOMImpl_IPlane.hxx:37
#define PLN_ARG_REF
Definition: GEOMImpl_IPlane.hxx:35
Definition: GEOMImpl_IPlane.hxx:29
Definition: GEOMImpl_IPlane.hxx:27
Definition: GEOMImpl_IPlane.hxx:41
#define PLN_ARG_LCS
Definition: GEOMImpl_IPlane.hxx:46
Definition: GEOMImpl_IPlane.hxx:31
Definition: GEOMImpl_IPlane.hxx:42
Definition: GEOMImpl_IPlane.hxx:49
Definition: GEOMImpl_IPlane.hxx:77
Definition: GEOMImpl_IPlane.hxx:64
Definition: GEOMImpl_IPlane.hxx:86
Definition: GEOMImpl_IPlane.hxx:89
Definition: GEOMImpl_IPlane.hxx:52
Definition: GEOMImpl_IPlane.hxx:71
Definition: GEOMImpl_IPlane.hxx:76
Definition: GEOMImpl_IPlane.hxx:90
Definition: GEOMImpl_IPlane.hxx:83
Handle(GEOM_Function) GetPoint()
Definition: GEOMImpl_IPlane.hxx:74
Definition: GEOMImpl_IPlane.hxx:72
void SetFace(Handle(GEOM_Function) theRef)
Definition: GEOMImpl_IPlane.hxx:67
Definition: GEOMImpl_IPlane.hxx:82
Definition: GEOMImpl_IPlane.hxx:70
Definition: GEOMImpl_IPlane.hxx:65
Definition: GEOMImpl_IPlane.hxx:75
double GetSize()
Definition: GEOMImpl_IPlane.hxx:56
Definition: GEOMImpl_IPlane.hxx:54
void SetPoint(Handle(GEOM_Function) theRef)
Definition: GEOMImpl_IPlane.hxx:62
Definition: GEOMImpl_IPlane.hxx:63
Definition: GEOMImpl_IPlane.hxx:84
Handle(GEOM_Function) GetFace()
Definition: GEOMImpl_IPlane.hxx:79
Definition: GEOMImpl_IPlane.hxx:87
Handle(GEOM_Function) GetLCS()
Definition: GEOMImpl_IPlane.hxx:80
Definition: GEOMImpl_IPlane.hxx:58
void SetLCS(Handle(GEOM_Function) theRef)
Definition: GEOMImpl_IPlane.hxx:68
Definition: GEOMImpl_IPlane.hxx:60
Standard_EXPORT gp_Vec GetVector(const TopoDS_Shape &theShape, Standard_Boolean doConsiderOrientation)
Get vector, defined by the given edge.
Definition: GEOMUtils.cxx:296
