GEOMImpl_IRotate.hxx
23// NOTE: This is an interface to a function for the Rotate operation.
24
25#include "GEOM_Function.hxx"
26
27#include <gp_XYZ.hxx>
28
29#define ROTATE_ANGLE 1
30#define ROTATE_AXIS 2
31#define ROTATE_ORGN 3
32#define ROTATE_STEP1 4
33#define ROTATE_NBITER1 5
34#define ROTATE_NBITER2 6
35#define ROTATE_CENTRAL_POINT 7
36#define ROTATE_POINT1 8
37#define ROTATE_POINT2 9
38#define ROTATE_DIR2_X 10
39#define ROTATE_DIR2_Y 11
40#define ROTATE_DIR2_Z 12
41
43{
44 public:
45
46 GEOMImpl_IRotate(Handle(GEOM_Function) theFunction): _func(theFunction) {}
47
48 void SetCentPoint(Handle(GEOM_Function) theCentPoint) { _func->SetReference(ROTATE_CENTRAL_POINT, theCentPoint); }
49
50 Handle(GEOM_Function) GetCentPoint() { return _func->GetReference(ROTATE_CENTRAL_POINT); }
51
52 void SetPoint1(Handle(GEOM_Function) thePoint1) { _func->SetReference(ROTATE_POINT1, thePoint1); }
53
54 Handle(GEOM_Function) GetPoint1() { return _func->GetReference(ROTATE_POINT1); }
55
56 void SetPoint2(Handle(GEOM_Function) thePoint2) { _func->SetReference(ROTATE_POINT2, thePoint2); }
57
58 Handle(GEOM_Function) GetPoint2() { return _func->GetReference(ROTATE_POINT2); }
59
60 void SetAngle(Standard_Real theAngle) { _func->SetReal(ROTATE_ANGLE, theAngle); }
61
62 Standard_Real GetAngle() { return _func->GetReal(ROTATE_ANGLE); }
63
64 void SetAxis(Handle(GEOM_Function) theVector) { _func->SetReference(ROTATE_AXIS, theVector); }
65
66 Handle(GEOM_Function) GetAxis() { return _func->GetReference(ROTATE_AXIS); }
67
68 void SetOriginal(Handle(GEOM_Function) theOriginal) { _func->SetReference(ROTATE_ORGN, theOriginal); }
69
70 Handle(GEOM_Function) GetOriginal() { return _func->GetReference(ROTATE_ORGN); }
71
72 void SetStep(double theStep) { _func->SetReal(ROTATE_STEP1, theStep); }
73
74 double GetStep() { return _func->GetReal(ROTATE_STEP1); }
75
76 void SetNbIter1(int theNbIter) { _func->SetInteger(ROTATE_NBITER1, theNbIter); }
77
78 int GetNbIter1() { return _func->GetInteger(ROTATE_NBITER1); }
79
80 void SetNbIter2(int theNbIter) { _func->SetInteger(ROTATE_NBITER2, theNbIter); }
81
82 int GetNbIter2() { return _func->GetInteger(ROTATE_NBITER2); }
83
84 void SetDir2 (gp_XYZ theDir2)
85 {
86 _func->SetReal(ROTATE_DIR2_X, theDir2.X());
87 _func->SetReal(ROTATE_DIR2_Y, theDir2.Y());
88 _func->SetReal(ROTATE_DIR2_Z, theDir2.Z());
89 }
90
91 gp_XYZ GetDir2()
92 {
93 gp_XYZ aRes (0., 0., 0.);
94 aRes.SetX(_func->GetReal(ROTATE_DIR2_X));
95 aRes.SetY(_func->GetReal(ROTATE_DIR2_Y));
96 aRes.SetZ(_func->GetReal(ROTATE_DIR2_Z));
97 return aRes;
98 }
99
100 private:
101
102 Handle(GEOM_Function) _func;
103};
Definition: GEOMImpl_IRotate.hxx:37
Definition: GEOMImpl_IRotate.hxx:39
Definition: GEOMImpl_IRotate.hxx:36
Definition: GEOMImpl_IRotate.hxx:29
Definition: GEOMImpl_IRotate.hxx:34
Definition: GEOMImpl_IRotate.hxx:40
Definition: GEOMImpl_IRotate.hxx:33
Definition: GEOMImpl_IRotate.hxx:32
Definition: GEOMImpl_IRotate.hxx:35
#define ROTATE_ORGN
Definition: GEOMImpl_IRotate.hxx:31
Definition: GEOMImpl_IRotate.hxx:38
#define ROTATE_AXIS
Definition: GEOMImpl_IRotate.hxx:30
Definition: GEOMImpl_IRotate.hxx:43
Definition: GEOMImpl_IRotate.hxx:56
Definition: GEOMImpl_IRotate.hxx:64
Definition: GEOMImpl_IRotate.hxx:54
Definition: GEOMImpl_IRotate.hxx:58
Definition: GEOMImpl_IRotate.hxx:66
void SetDir2(gp_XYZ theDir2)
Definition: GEOMImpl_IRotate.hxx:84
Definition: GEOMImpl_IRotate.hxx:48
gp_XYZ GetDir2()
Definition: GEOMImpl_IRotate.hxx:91
Definition: GEOMImpl_IRotate.hxx:50
double GetStep()
Definition: GEOMImpl_IRotate.hxx:74
Definition: GEOMImpl_IRotate.hxx:72
Definition: GEOMImpl_IRotate.hxx:70
int GetNbIter2()
Definition: GEOMImpl_IRotate.hxx:82
Definition: GEOMImpl_IRotate.hxx:68
int GetNbIter1()
Definition: GEOMImpl_IRotate.hxx:78
Definition: GEOMImpl_IRotate.hxx:80
Definition: GEOMImpl_IRotate.hxx:62
Definition: GEOMImpl_IRotate.hxx:60
Definition: GEOMImpl_IRotate.hxx:46
Definition: GEOMImpl_IRotate.hxx:52
Definition: GEOMImpl_IRotate.hxx:76
