GEOMImpl_VectorDriver.hxx
23// File : GEOMImpl_VectorDriver.hxx
24// Module : GEOMImpl
25//
26#ifndef _GEOMImpl_VectorDriver_HeaderFile
27#define _GEOMImpl_VectorDriver_HeaderFile
28
29#include <GEOM_BaseDriver.hxx>
30
31DEFINE_STANDARD_HANDLE( GEOMImpl_VectorDriver, GEOM_BaseDriver )
32
33class GEOMImpl_VectorDriver : public GEOM_BaseDriver {
34
35public:
36
37 Standard_EXPORT GEOMImpl_VectorDriver();
38 Standard_EXPORT virtual Standard_Integer Execute(Handle(TFunction_Logbook)& log) const;
39 Standard_EXPORT virtual void Validate(Handle(TFunction_Logbook)&) const {}
40 Standard_EXPORT Standard_Boolean MustExecute(const Handle(TFunction_Logbook)&) const { return Standard_True; }
41
42 Standard_EXPORT static const Standard_GUID& GetID();
43 Standard_EXPORT ~GEOMImpl_VectorDriver() {};
44
45 Standard_EXPORT virtual
46 bool GetCreationInformation(std::string& theOperationName,
47 std::vector<GEOM_Param>& params);
48
49 DEFINE_STANDARD_RTTIEXT(GEOMImpl_VectorDriver,GEOM_BaseDriver)
50
51};
52
53#endif
