GEOM_BaseDriver.hxx
23// File : GEOM_BaseDriver.hxx
24// Created : Thu Jun 6 15:27:50 2013
25// Author : Edward AGAPOV (eap)
26
27#ifndef __GEOM_BaseDriver_HXX__
28#define __GEOM_BaseDriver_HXX__
30#include "GEOM_Function.hxx"
31
32#include <TFunction_Driver.hxx>
33#include <TFunction_Logbook.hxx>
34#include <TopAbs_ShapeEnum.hxx>
35#include <TopAbs_State.hxx>
36#include <TColStd_HSequenceOfTransient.hxx>
37#include <TColStd_HArray1OfInteger.hxx>
38
39#include <string>
40#include <vector>
41#include <sstream>
42
44{
45 std::string name;
46 std::string value;
47
48 Standard_EXPORT void Set(const char* nm) { name = nm; }
49 template <class T>
50 Standard_EXPORT void Set(const char* nm, const T& value) { name = nm; (*this)<<value; }
51
52 template <class T> Standard_EXPORT GEOM_Param & operator<<( const T &anything )
53 {
54 std::ostringstream str;
55 str << anything;
56 value += str.str() ;
57 return *this ;
58 }
59 Standard_EXPORT GEOM_Param & operator<<( const Handle(GEOM_Function)& fun );
60 Standard_EXPORT GEOM_Param & operator<<( const Handle(Standard_Transient)& fun );
61 Standard_EXPORT GEOM_Param & operator<<( const Handle(TColStd_HSequenceOfTransient)& funs );
62 Standard_EXPORT GEOM_Param & operator<<( const Handle(TColStd_HArray1OfInteger)& vals );
63 Standard_EXPORT GEOM_Param & operator<<( TopAbs_ShapeEnum type );
64 Standard_EXPORT GEOM_Param & operator<<( TopAbs_State state );
65};
66
67
69{
70public:
71
72 // Returns a name of creation operation and names and values of creation parameters
73 // (Use AddParam() methods declared below to fill params vector while implementing
74 // this method in derived drivers)
75 Standard_EXPORT virtual
76 bool GetCreationInformation(std::string& theOperationName,
77 std::vector<GEOM_Param>& params) = 0;
78
79 // Adds GEOM_Param to params and sets its name
80 // This method is safer than resizing the params vector and accessing to its items
81 Standard_EXPORT GEOM_Param& AddParam(std::vector<GEOM_Param>& params,
82 const char* name);
83
84 // Adds GEOM_Param to params vector and sets its name and value
85 // This method is safer than resizing the params vector and accessing to its items
86 template <class T>
87 Standard_EXPORT GEOM_Param& AddParam(std::vector<GEOM_Param>& params,
88 const char* name,
89 const T& value,
90 const char* dfltValue = 0)
91 {
92 GEOM_Param p;
93 p.Set( name, value );
94 if ( dfltValue && p.value.empty() )
95 p << dfltValue;
96 params.push_back( p );
97 return params.back();
98 }
99
100 DEFINE_STANDARD_RTTIEXT(GEOM_BaseDriver,TFunction_Driver)
101};
102
104
105#endif
Standard_EXPORT GEOM_Param & AddParam(std::vector< GEOM_Param > &params, const char *name, const T &value, const char *dfltValue=0)
Definition: GEOM_BaseDriver.hxx:87
Standard_EXPORT GEOM_Param & AddParam(std::vector< GEOM_Param > &params, const char *name)
Definition: GEOM_BaseDriver.hxx:44
Standard_EXPORT void Set(const char *nm)
Definition: GEOM_BaseDriver.hxx:48
std::string name
Definition: GEOM_BaseDriver.hxx:45
Standard_EXPORT void Set(const char *nm, const T &value)
Definition: GEOM_BaseDriver.hxx:50
Standard_EXPORT GEOM_Param & operator<<(const T &anything)
Definition: GEOM_BaseDriver.hxx:52
std::string value
Definition: GEOM_BaseDriver.hxx:46
