GEOM_Field_i.hh
23#ifndef _GEOM_Field_i_HeaderFile
24#define _GEOM_Field_i_HeaderFile
26#include "GEOMImpl_Gen.hxx"
27#include "GEOM_BaseObject_i.hh"
28#include "GEOM_Field.hxx"
30#include <SALOMEconfig.h>
31#include CORBA_SERVER_HEADER(GEOM_Gen)
32
33#include <TopoDS_Shape.hxx>
34
35//================================================================================
39class GEOM_I_EXPORT GEOM_Field_i : public virtual POA_GEOM::GEOM_Field, public virtual GEOM_BaseObject_i
40{
41 public:
42 GEOM_Field_i(PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, Handle(::GEOM_Field) theImpl);
44
45 virtual GEOM::GEOM_Object_ptr GetShape();
46 virtual GEOM::field_data_type GetDataType();
47 virtual CORBA::Short GetDimension();
48 virtual GEOM::string_array* GetComponents();
49 virtual GEOM::GEOM_FieldStep_ptr AddStep(::CORBA::Long stepID, ::CORBA::Long stamp);
50 virtual void RemoveStep(::CORBA::Long stepID);
51 virtual CORBA::Long CountSteps();
52 virtual GEOM::ListOfLong* GetSteps();
53 virtual GEOM::GEOM_FieldStep_ptr GetStep(CORBA::Long stepID);
54 virtual ::CORBA::Boolean IsShape() { return false; }
55 virtual CORBA::Long GetArraySize();
56
57 private:
58
60};
61
62//================================================================================
66class GEOM_I_EXPORT GEOM_FieldStep_i : public virtual POA_GEOM::GEOM_FieldStep, public virtual GEOM_BaseObject_i
67{
68 public:
69 GEOM_FieldStep_i(PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, Handle(::GEOM_FieldStep) theImpl);
71
72 virtual void SetStamp(::CORBA::Long stamp);
73 virtual ::CORBA::Long GetStamp();
74 virtual ::CORBA::Long GetID();
75 virtual GEOM::GEOM_Field_ptr GetField();
76 virtual ::CORBA::Boolean IsShape() { return false; }
77
78 protected:
79
81};
82
83//================================================================================
87class GEOM_I_EXPORT GEOM_BoolFieldStep_i : public virtual POA_GEOM::GEOM_BoolFieldStep, public virtual GEOM_FieldStep_i
88{
89 public:
90 GEOM_BoolFieldStep_i(PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, Handle(::GEOM_FieldStep) theImpl);
91
92 virtual ::CORBA::Boolean SetValues(const ::GEOM::short_array& boolValues);
93 virtual GEOM::short_array* GetValues();
94};
95
96//================================================================================
100class GEOM_I_EXPORT GEOM_IntFieldStep_i : public virtual POA_GEOM::GEOM_IntFieldStep, public virtual GEOM_FieldStep_i
101{
102 public:
103 GEOM_IntFieldStep_i(PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, Handle(::GEOM_FieldStep) theImpl);
104
105 virtual ::CORBA::Boolean SetValues(const ::GEOM::ListOfLong& intValues);
106 virtual GEOM::ListOfLong* GetValues();
107};
108
109//================================================================================
113class GEOM_I_EXPORT GEOM_DoubleFieldStep_i : public virtual POA_GEOM::GEOM_DoubleFieldStep, public virtual GEOM_FieldStep_i
114{
115 public:
116 GEOM_DoubleFieldStep_i(PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, Handle(::GEOM_FieldStep) theImpl);
117
118 virtual ::CORBA::Boolean SetValues(const ::GEOM::ListOfDouble& doubleValues);
119 virtual GEOM::ListOfDouble* GetValues();
120};
121
122//================================================================================
126class GEOM_I_EXPORT GEOM_StringFieldStep_i : public virtual POA_GEOM::GEOM_StringFieldStep, public virtual GEOM_FieldStep_i
127{
128 public:
129 GEOM_StringFieldStep_i(PortableServer::POA_ptr thePOA, GEOM::GEOM_Gen_ptr theEngine, Handle(::GEOM_FieldStep) theImpl);
130
131 virtual ::CORBA::Boolean SetValues(const ::GEOM::string_array& strValues);
132 virtual GEOM::string_array* GetValues();
133};
134
135#endif
#define GEOM_I_EXPORT
Definition: GEOM_GEOM_I.hxx:33
Definition: GEOM_BaseObject_i.hh:38
Handle(::GEOM_BaseObject) GetImpl()
Definition: GEOM_BaseObject_i.hh:71
Class implementing GEOM::GEOM_BoolFieldStep interface.
Definition: GEOM_Field_i.hh:88
Class implementing GEOM::GEOM_DoubleFieldStep interface.
Definition: GEOM_Field_i.hh:114
Class implementing GEOM::GEOM_FieldStep interface.
Definition: GEOM_Field_i.hh:67
Handle(::GEOM_FieldStep) _impl
Definition: GEOM_Field_i.hh:76
Definition: GEOM_Field.hxx:135
Class implementing GEOM::GEOM_Field interface.
Definition: GEOM_Field_i.hh:40
Definition: GEOM_Field_i.hh:54
Handle(::GEOM_Field) _impl
Definition: GEOM_Field.hxx:40
Class implementing GEOM::GEOM_IntFieldStep interface.
Definition: GEOM_Field_i.hh:101
Class implementing GEOM::GEOM_StringFieldStep interface.
Definition: GEOM_Field_i.hh:127
sequence< double > ListOfDouble
Definition: GEOM_Gen.idl:280
sequence< short > short_array
Definition: GEOM_Gen.idl:277
sequence< long > ListOfLong
Definition: GEOM_Gen.idl:279
sequence< string > string_array
Definition: GEOM_Gen.idl:276
field_data_type
Type of field data.
Definition: GEOM_Gen.idl:191
