GEOM_IField.hxx
23//NOTE: This is an interface to a function for the Field creation.
24//
25#include "GEOM_Function.hxx"
26
27#include <TColStd_HArray1OfExtendedString.hxx>
28#include <TColStd_HArray1OfInteger.hxx>
29#include <TColStd_HArray1OfReal.hxx>
30
31class GEOM_Field;
32
34{
35 enum {
36 // field
37 FIELD_SHAPE = 1, // ref
38 FIELD_DATATYPE = 1, // int
39 FIELD_DIMENSION = 2, // int
40 FIELD_COMPONENTS = 1, // string array
41 // field step
42 STEP_FIELD = 1, // ref
43 STEP_ID = 1, // int
44 STEP_STAMP = 2, // int
45 STEP_VALUES = 2 // an array of any type
46 };
47
48public:
49
50 GEOM_IField(Handle(GEOM_Function) theFunction): _func(theFunction) {}
51
52 Standard_EXPORT Handle(GEOM_Function) GetShape()
53 { return _func->GetReference( FIELD_SHAPE ); }
54 Standard_EXPORT int GetDataType() { return _func->GetInteger( FIELD_DATATYPE ); }
55 Standard_EXPORT int GetDimension() { return _func->GetInteger( FIELD_DIMENSION ); }
56 Standard_EXPORT Handle(TColStd_HArray1OfExtendedString) GetComponents()
57 { return _func->GetStringArray( FIELD_COMPONENTS ); }
58
59 Standard_EXPORT Handle(GEOM_Function) GetField()
60 { return _func->GetReference( STEP_FIELD ); }
61 Standard_EXPORT int GetStepID() { return _func->GetInteger( STEP_ID ); }
62 Standard_EXPORT int GetStepStamp() { return _func->GetInteger( STEP_STAMP ); }
63 Standard_EXPORT Handle(TColStd_HArray1OfInteger) GetIntValues()
64 { return _func->GetIntegerArray( STEP_VALUES ); }
65 Standard_EXPORT Handle(TColStd_HArray1OfReal) GetDoubleValues()
66 { return _func->GetRealArray( STEP_VALUES ); }
67 Standard_EXPORT Handle(TColStd_HArray1OfExtendedString) GetStringValues()
68 { return _func->GetStringArray( STEP_VALUES ); }
69
70 private:
71
72 void SetShape(Handle(GEOM_Function) theS) { _func->SetReference( FIELD_SHAPE, theS ); }
73 void SetDataType( int type ) { _func->SetInteger( FIELD_DATATYPE, type ); }
74 void SetDimension( int dim ) { _func->SetInteger( FIELD_DIMENSION, dim ); }
75 void SetComponents( const Handle(TColStd_HArray1OfExtendedString)& compNames )
76 { _func->SetStringArray( FIELD_COMPONENTS, compNames ); }
77
78 friend class GEOM_Field;
79
80 void SetField(Handle(GEOM_Function) theF) { _func->SetReference( STEP_FIELD, theF ); }
81 void SetStepStamp( int stamp ) { _func->SetInteger( STEP_STAMP, stamp ); }
82 void SetStepID( int step ) { _func->SetInteger( STEP_ID, step ); }
83 // void SetStepIDs( Handle(TColStd_HArray1OfInteger) steps )
84 // { _func->SetRealArray( FIELD_STEP_IDS, steps ); }
85 void SetValues( const Handle(TColStd_HArray1OfInteger)& values )
86 { _func->SetIntegerArray( STEP_VALUES, values ); }
87 void SetValues( const Handle(TColStd_HArray1OfReal)& values )
88 { _func->SetRealArray( STEP_VALUES, values ); }
89 void SetValues( const Handle(TColStd_HArray1OfExtendedString)& values )
90 { _func->SetStringArray( STEP_VALUES, values ); }
91
92 friend class GEOM_FieldStep;
93
94 Handle(GEOM_Function) _func;
95};
Definition: GEOM_Field.hxx:135
Definition: GEOM_Field.hxx:40
Standard_EXPORT const int stamp
Definition: GEOM_Field.hxx:115
Definition: GEOM_IField.hxx:34
void SetValues(const Handle(TColStd_HArray1OfExtendedString)&values)
Definition: GEOM_IField.hxx:89
void SetStepStamp(int stamp)
Definition: GEOM_IField.hxx:81
Definition: GEOM_IField.hxx:62
Definition: GEOM_IField.hxx:65
Definition: GEOM_IField.hxx:56
Definition: GEOM_IField.hxx:63
void SetValues(const Handle(TColStd_HArray1OfInteger)&values)
Definition: GEOM_IField.hxx:85
Definition: GEOM_IField.hxx:61
Definition: GEOM_IField.hxx:72
Definition: GEOM_IField.hxx:50
void SetComponents(const Handle(TColStd_HArray1OfExtendedString)&compNames)
Definition: GEOM_IField.hxx:75
Definition: GEOM_IField.hxx:54
@ STEP_VALUES
Definition: GEOM_IField.hxx:45
@ FIELD_DIMENSION
Definition: GEOM_IField.hxx:39
@ FIELD_COMPONENTS
Definition: GEOM_IField.hxx:40
@ FIELD_SHAPE
Definition: GEOM_IField.hxx:37
@ STEP_ID
Definition: GEOM_IField.hxx:43
@ FIELD_DATATYPE
Definition: GEOM_IField.hxx:38
@ STEP_STAMP
Definition: GEOM_IField.hxx:44
@ STEP_FIELD
Definition: GEOM_IField.hxx:42
void SetDataType(int type)
Definition: GEOM_IField.hxx:73
Definition: GEOM_IField.hxx:80
Definition: GEOM_IField.hxx:59
void SetValues(const Handle(TColStd_HArray1OfReal)&values)
Definition: GEOM_IField.hxx:87
Definition: GEOM_IField.hxx:52
Definition: GEOM_IField.hxx:55
void SetDimension(int dim)
Definition: GEOM_IField.hxx:74
void SetStepID(int step)
Definition: GEOM_IField.hxx:82
Definition: GEOM_IField.hxx:67
