GenerationGUI_PipeDlg.h
24// File : GenerationGUI_PipeDlg.h
25// Author : Lucien PIGNOLONI, Open CASCADE S.A.S.
26//
27#ifndef GENERATIONGUI_PIPEDLG_H
28#define GENERATIONGUI_PIPEDLG_H
30#include "GEOMBase_Skeleton.h"
31#include "GEOM_GenericObjPtr.h"
32
33typedef std::map<QString, QList<GEOM::GeomObjPtr> > ObjectMap;
34
35
38
39//=================================================================================
40// class : GenerationGUI_PipeDlg
41// purpose :
42//=================================================================================
44{
45 Q_OBJECT
46
47public:
48 GenerationGUI_PipeDlg( GeometryGUI*, QWidget* = 0, bool = false, Qt::WindowFlags = 0 );
50
51protected:
52 // redefined from GEOMBase_Helper
53 virtual GEOM::GEOM_IOperations_ptr createOperation();
54 virtual bool isValid( QString& );
55 virtual bool execute( ObjectList& );
56 virtual void addSubshapesToStudy();
57 virtual bool extractPrefix() const;
58 virtual void restoreSubShapes(SALOMEDS::SObject_ptr);
59 virtual QList<GEOM::GeomObjPtr> getSourceObjects();
60
61private:
62 void Init();
63 void enterEvent( QEvent* );
64 void updateGenGroup();
65 void resetGenGroup
66 (QCheckBox *theGenGroup,
67 const bool isChecked,
68 const bool isClearPrefix);
69 void addGroups
70 (GEOM::ListOfGO_var &theResult);
71
72private:
73 QList<GEOM::GeomObjPtr> myBaseObjects; /* Base shapes */
74 GEOM::GeomObjPtr myPath; /* Shape, defining the path */
75 GEOM::GeomObjPtr myVec; /* Vector, defining the constant binormal direction */
76 QList<GEOM::GeomObjPtr> myLocations; /* Locations on the path corresponding specified list of the Base shapes */
77
82 QLineEdit *myPrefixEditGP;
86 QLineEdit *myPrefixEditGMP;
88
89private slots:
90 void ClickOnOk();
91 bool ClickOnApply();
92 void ActivateThisDialog();
95 void ConstructorsClicked( int );
97 void GenGroupClicked(bool);
98 void StepByStepClicked(bool);
99};
100
101#endif // GENERATIONGUI_PIPEDLG_H
std::map< QString, QList< GEOM::GeomObjPtr > > ObjectMap
Definition: GenerationGUI_PipeDlg.h:33
Definition: DlgRef.h:703
Definition: DlgRef.h:769
Definition: GenerationGUI_PipeDlg.h:44
QCheckBox * myGenGroupCheckGP
Definition: GenerationGUI_PipeDlg.h:80
QLineEdit * myPrefixEditGP
Definition: GenerationGUI_PipeDlg.h:82
GenerationGUI_PipeDlg(GeometryGUI *, QWidget *=0, bool=false, Qt::WindowFlags=0)
Definition: GenerationGUI_PipeDlg.cxx:51
bool ClickOnApply()
Definition: GenerationGUI_PipeDlg.cxx:314
void Init()
Definition: GenerationGUI_PipeDlg.cxx:166
Definition: GenerationGUI_PipeDlg.cxx:503
DlgRef_3Sel1Check * GroupPoints
Definition: GenerationGUI_PipeDlg.h:78
Definition: GenerationGUI_PipeDlg.cxx:734
void SetEditCurrentArgument()
Definition: GenerationGUI_PipeDlg.cxx:411
void ConstructorsClicked(int)
Definition: GenerationGUI_PipeDlg.cxx:230
void addGroups(GEOM::ListOfGO_var &theResult)
Definition: GenerationGUI_PipeDlg.cxx:802
QList< GEOM::GeomObjPtr > myLocations
Definition: GenerationGUI_PipeDlg.h:76
ObjectMap myGroupObjectsMap
Definition: GenerationGUI_PipeDlg.h:87
Definition: GenerationGUI_PipeDlg.h:75
DlgRef_3Sel2Check3Spin * GroupMakePoints
Definition: GenerationGUI_PipeDlg.h:79
Definition: GenerationGUI_PipeDlg.cxx:635
Definition: GenerationGUI_PipeDlg.cxx:625
Definition: GenerationGUI_PipeDlg.cxx:715
void SelectionTypeButtonClicked()
Definition: GenerationGUI_PipeDlg.cxx:279
void ClickOnOk()
Definition: GenerationGUI_PipeDlg.cxx:303
Definition: GenerationGUI_PipeDlg.cxx:512
QList< GEOM::GeomObjPtr > myBaseObjects
Definition: GenerationGUI_PipeDlg.h:73
QLabel * myPrefixLblGMP
Definition: GenerationGUI_PipeDlg.h:85
Definition: GenerationGUI_PipeDlg.cxx:702
QLabel * myPrefixLblGP
Definition: GenerationGUI_PipeDlg.h:81
QCheckBox * myGenGroupCheckGMP
Definition: GenerationGUI_PipeDlg.h:84
void SelectionIntoArgument()
Definition: GenerationGUI_PipeDlg.cxx:328
void enterEvent(QEvent *)
Definition: GenerationGUI_PipeDlg.cxx:493
Definition: GenerationGUI_PipeDlg.cxx:645
void resetGenGroup(QCheckBox *theGenGroup, const bool isChecked, const bool isClearPrefix)
Definition: GenerationGUI_PipeDlg.cxx:773
~GenerationGUI_PipeDlg()
Definition: GenerationGUI_PipeDlg.cxx:157
Definition: GenerationGUI_PipeDlg.cxx:724
QCheckBox * myStepByStepCheckGMP
Definition: GenerationGUI_PipeDlg.h:83
Definition: GenerationGUI_PipeDlg.cxx:480
Definition: GenerationGUI_PipeDlg.h:74
Definition: GenerationGUI_PipeDlg.cxx:535
QLineEdit * myPrefixEditGMP
Definition: GenerationGUI_PipeDlg.h:86
Definition: GeometryGUI.h:74
GenericObjPtr< GEOM::GEOM_Object > GeomObjPtr
Definition: GEOM_GenericObjPtr.h:218
