MeasureGUI_CheckSelfIntersectionsDlg.h
24// File : MeasureGUI_CheckSelfIntersectionsDlg.h
26#ifndef MEASUREGUI_CHECKSELFINTERDLG_H
27#define MEASUREGUI_CHECKSELFINTERDLG_H
28
29#include <GEOMBase_Skeleton.h>
30
31class QComboBox;
32class QListWidget;
33class QTextBrowser;
34
35
36//=================================================================================
37// class : MeasureGUI_CheckSelfIntersectionsDlg
38// purpose :
39//=================================================================================
40
42{
43 Q_OBJECT
44
45public:
46
49
50protected:
51 // redefined from GEOMBase_Helper
52 virtual GEOM::GEOM_IOperations_ptr createOperation();
53 virtual bool isValid(QString &);
54 virtual bool execute(ObjectList &);
55 virtual bool extractPrefix() const;
56 virtual GEOM::GEOM_Object_ptr getFather (GEOM::GEOM_Object_ptr);
57 virtual QList<GEOM::GeomObjPtr> getSourceObjects();
58
59private slots:
60
63 void clear();
64 void onCompute();
65 void ClickOnOk();
66 bool ClickOnApply();
67 void ActivateThisDialog();
71 void ConstructorsClicked (int);
72 void OnGaps(bool);
73
74
75private:
76
77 void Init();
78 void activateSelection();
79 void enterEvent(QEvent *);
81 (bool &HasSelfInte,
82 QString &theErrMsg);
83 float getDeflection();
84 double getTolerance();
85
86// Getters
87 QTextBrowser* getTextView();
90 QPushButton* getComputeButton();
91 QLineEdit* getEditObjName();
93 GEOM::ListOfLong_var getInters();
94
95
96private:
98 // simple
99 QPushButton *myComputeButton1;
101 QTextBrowser *myTextView1;
102 QPushButton *mySelButton1;
103 QLineEdit *myEditObjName1;
104 QComboBox *myLevelBox;
108 GEOM::ListOfLong_var myInters1;
109 // fast
110 QPushButton *myComputeButton2;
112 QTextBrowser *myTextView2;
113 QPushButton *mySelButton2;
114 QLineEdit *myEditObjName2;
115 QCheckBox *myDetGaps;
116 SalomeApp_DoubleSpinBox *myTolerance;
117 SalomeApp_DoubleSpinBox *myDeflection;
121 GEOM::ListOfLong_var myInters2;
122 GEOM::GEOM_IShapesOperations_var myShapesOper;
123};
124
125#endif // MEASUREGUI_CHECKSELFINTERDLG_H
Definition: GeometryGUI.h:74
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:42
QPushButton * mySelButton1
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:102
bool findSelfIntersections(bool &HasSelfInte, QString &theErrMsg)
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:569
MeasureGUI_CheckSelfIntersectionsDlg(GeometryGUI *, QWidget *)
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:60
void onCompute()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:354
QPushButton * myComputeButton1
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:99
QTextBrowser * myTextView1
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:101
QCheckBox * myDetGaps
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:115
void OnGaps(bool)
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:515
void SetEditCurrentArgument()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:505
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:750
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:121
QPushButton * getComputeButton()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:798
QPushButton * mySelButton2
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:113
void onInteListSelectionChanged()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:619
QListWidget * myInteList2
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:118
QListWidget * getShapeList()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:793
QListWidget * getInteList()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:788
GEOM::GeomObjPtr myObj1
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:107
QListWidget * myInteList1
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:105
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:741
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:426
QListWidget * myShapeList1
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:106
~MeasureGUI_CheckSelfIntersectionsDlg()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:211
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:773
void clear()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:296
QLineEdit * myEditObjName1
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:103
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:496
GEOM::GeomObjPtr getObj()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:808
QGroupBox * myFastGrp
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:111
QLineEdit * getEditObjName()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:803
void Init()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:219
QListWidget * myShapeList2
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:119
QTextBrowser * myTextView2
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:112
QPushButton * myComputeButton2
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:110
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:689
void ConstructorsClicked(int)
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:317
bool ClickOnApply()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:461
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:478
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:813
SalomeApp_DoubleSpinBox * myDeflection
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:117
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:401
GEOM::GeomObjPtr myObj2
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:120
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:487
void onSubShapesListSelectionChanged()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:650
void SelectionIntoArgument()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:524
void ClickOnOk()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:451
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:108
QGroupBox * mySimpleGrp
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:100
QLineEdit * myEditObjName2
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:114
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:122
int myCurrConstrId
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:97
QComboBox * myLevelBox
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:104
void DeactivateActiveDialog()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:417
SalomeApp_DoubleSpinBox * myTolerance
Definition: MeasureGUI_CheckSelfIntersectionsDlg.h:116
QTextBrowser * getTextView()
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:783
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:558
virtual GEOM::GEOM_Object_ptr getFather(GEOM::GEOM_Object_ptr)
Definition: MeasureGUI_CheckSelfIntersectionsDlg.cxx:764
GenericObjPtr< GEOM::GEOM_Object > GeomObjPtr
Definition: GEOM_GenericObjPtr.h:218
