MeasureGUI_GetNonBlocksDlg.h
24// File : MeasureGUI_GetNonBlocksDlg.h
26#ifndef MEASUREGUI_GETNONBLOCKSDLG_H
27#define MEASUREGUI_GETNONBLOCKSDLG_H
28
29#include <GEOMBase_Skeleton.h>
30
31class QCheckBox;
32class QLabel;
33class QLineEdit;
34class QPushButton;
35class SalomeApp_DoubleSpinBox;
36
37//=================================================================================
38// class : MeasureGUI_GetNonBlocksDlg
39// purpose :
40//=================================================================================
42{
43 Q_OBJECT
44
45public:
48
49protected:
50 // redefined from GEOMBase_Helper
51 virtual GEOM::GEOM_IOperations_ptr createOperation();
52 virtual bool isValid (QString &msg);
53 virtual bool execute (ObjectList&);
54 virtual GEOM::GEOM_Object_ptr getFather (GEOM::GEOM_Object_ptr);
55 virtual QList<GEOM::GeomObjPtr> getSourceObjects();
56
57private slots:
58 void ClickOnOk();
59 bool ClickOnApply();
60 void ActivateThisDialog();
64 void SetUseC1Tolerance();
65
66private:
67 void Init();
68 void enterEvent (QEvent*);
69 void processObject();
70
71private:
72 GEOM::GEOM_Object_var myObj;
73 QLineEdit *myObjectName;
74 QPushButton *mySelButton;
75 QCheckBox *myUseC1Check;
76 QLabel *myTolLbl;
77 SalomeApp_DoubleSpinBox *mySpinTol;
78};
79
80#endif // MEASUREGUI_GETNONBLOCKSDLG_H
Definition: GeometryGUI.h:74
Definition: MeasureGUI_GetNonBlocksDlg.h:42
~MeasureGUI_GetNonBlocksDlg()
Definition: MeasureGUI_GetNonBlocksDlg.cxx:117
void enterEvent(QEvent *)
Definition: MeasureGUI_GetNonBlocksDlg.cxx:278
QLabel * myTolLbl
Definition: MeasureGUI_GetNonBlocksDlg.h:76
void Init()
Definition: MeasureGUI_GetNonBlocksDlg.cxx:125
MeasureGUI_GetNonBlocksDlg(GeometryGUI *, QWidget *)
Definition: MeasureGUI_GetNonBlocksDlg.cxx:54
Definition: MeasureGUI_GetNonBlocksDlg.cxx:341
Definition: MeasureGUI_GetNonBlocksDlg.h:72
QLineEdit * myObjectName
Definition: MeasureGUI_GetNonBlocksDlg.h:73
QCheckBox * myUseC1Check
Definition: MeasureGUI_GetNonBlocksDlg.h:75
Definition: MeasureGUI_GetNonBlocksDlg.cxx:246
SalomeApp_DoubleSpinBox * mySpinTol
Definition: MeasureGUI_GetNonBlocksDlg.h:77
void LineEditReturnPressed()
Definition: MeasureGUI_GetNonBlocksDlg.cxx:233
void SetEditCurrentArgument()
Definition: MeasureGUI_GetNonBlocksDlg.cxx:211
QPushButton * mySelButton
Definition: MeasureGUI_GetNonBlocksDlg.h:74
Definition: MeasureGUI_GetNonBlocksDlg.cxx:288
void SelectionIntoArgument()
Definition: MeasureGUI_GetNonBlocksDlg.cxx:181
virtual GEOM::GEOM_Object_ptr getFather(GEOM::GEOM_Object_ptr)
Definition: MeasureGUI_GetNonBlocksDlg.cxx:332
Definition: MeasureGUI_GetNonBlocksDlg.cxx:222
Definition: MeasureGUI_GetNonBlocksDlg.cxx:261
bool ClickOnApply()
Definition: MeasureGUI_GetNonBlocksDlg.cxx:168
void ClickOnOk()
Definition: MeasureGUI_GetNonBlocksDlg.cxx:158
virtual bool isValid(QString &msg)
Definition: MeasureGUI_GetNonBlocksDlg.cxx:297
Definition: MeasureGUI_GetNonBlocksDlg.cxx:306
