OperationGUI_GetSharedShapesDlg.h
22// File : OperationGUI_GetSharedShapesDlg.h
23// Author : Julia DOROVSKIKH, Open CASCADE S.A.S.
24
25#ifndef OPERATIONGUI_GETSHAREDSHAPESDLG_H
26#define OPERATIONGUI_GETSHAREDSHAPESDLG_H
27
28#include <GEOMBase_Skeleton.h>
31
32//=================================================================================
33// class : OperationGUI_GetSharedShapesDlg
34// purpose :
35//=================================================================================
37{
38 Q_OBJECT
39
40public:
43
44protected:
45 // redefined from GEOMBase_Helper
46 virtual GEOM::GEOM_IOperations_ptr createOperation();
47 virtual bool isValid (QString&);
48 virtual bool execute (ObjectList&);
49 virtual GEOM::GEOM_Object_ptr getFather (GEOM::GEOM_Object_ptr);
50 QString getPrefixByType() const;
51 virtual QList<GEOM::GeomObjPtr> getSourceObjects();
52
53private:
54 void Init();
55 void enterEvent (QEvent*);
56 int GetType() const;
57 void initTypes();
58
59private:
61
63
64private slots:
65 void ClickOnOk();
66 bool ClickOnApply();
67 void ActivateThisDialog();
70 void ConstructorsClicked (int);
71 void ComboTextChanged();
72};
73
74#endif // OPERATIONGUI_GETSHAREDSHAPESDLG_H
Definition: DlgRef.h:351
Definition: GeometryGUI.h:74
Definition: OperationGUI_GetSharedShapesDlg.h:37
Definition: OperationGUI_GetSharedShapesDlg.cxx:411
Definition: OperationGUI_GetSharedShapesDlg.cxx:311
void SetEditCurrentArgument()
Definition: OperationGUI_GetSharedShapesDlg.cxx:267
Definition: OperationGUI_GetSharedShapesDlg.cxx:287
GEOM::ListOfGO myListShapes
Definition: OperationGUI_GetSharedShapesDlg.h:60
~OperationGUI_GetSharedShapesDlg()
Definition: OperationGUI_GetSharedShapesDlg.cxx:113
Definition: OperationGUI_GetSharedShapesDlg.cxx:356
bool ClickOnApply()
Definition: OperationGUI_GetSharedShapesDlg.cxx:222
void ClickOnOk()
Definition: OperationGUI_GetSharedShapesDlg.cxx:211
Definition: OperationGUI_GetSharedShapesDlg.cxx:332
DlgRef_2Sel1List1Check * GroupPoints
Definition: OperationGUI_GetSharedShapesDlg.h:62
Definition: OperationGUI_GetSharedShapesDlg.cxx:341
virtual GEOM::GEOM_Object_ptr getFather(GEOM::GEOM_Object_ptr)
Definition: OperationGUI_GetSharedShapesDlg.cxx:378
void initTypes()
Definition: OperationGUI_GetSharedShapesDlg.cxx:152
void Init()
Definition: OperationGUI_GetSharedShapesDlg.cxx:122
void SelectionIntoArgument()
Definition: OperationGUI_GetSharedShapesDlg.cxx:237
Definition: OperationGUI_GetSharedShapesDlg.cxx:390
void ConstructorsClicked(int)
Definition: OperationGUI_GetSharedShapesDlg.cxx:185
int GetType() const
Definition: OperationGUI_GetSharedShapesDlg.cxx:322
void enterEvent(QEvent *)
Definition: OperationGUI_GetSharedShapesDlg.cxx:301
OperationGUI_GetSharedShapesDlg(GeometryGUI *, QWidget *=0)
Definition: OperationGUI_GetSharedShapesDlg.cxx:69
sequence< GEOM_Object > ListOfGO
Definition: GEOM_Gen.idl:290
