RepairGUI_RemoveHolesDlg.h
24// File : RepairGUI_RemoveHolesDlg.h
25// Author : Lucien PIGNOLONI, Open CASCADE S.A.S.
26//
27#ifndef REPAIRGUI_REMOVEHOLESDLG_H
28#define REPAIRGUI_REMOVEHOLESDLG_H
30#include <GEOMBase_Skeleton.h>
31
33class QPushButton;
34
35//=================================================================================
36// class : RepairGUI_RemoveHolesDlg
37// purpose :
38//=================================================================================
40{
41 Q_OBJECT
42
43public:
44 RepairGUI_RemoveHolesDlg( GeometryGUI*, QWidget* = 0, bool = false );
46
47protected:
48 // redefined from GEOMBase_Helper
49 virtual GEOM::GEOM_IOperations_ptr createOperation();
50 virtual bool isValid( QString& );
51 virtual bool execute( ObjectList& );
52 virtual QList<GEOM::GeomObjPtr> getSourceObjects();
53
54private:
55 void Init();
56 void enterEvent( QEvent* );
57 void initSelection();
58
59private:
60 GEOM::GEOM_Object_var myObject;
61 GEOM::short_array_var myWiresInd;
62
64 QPushButton* myFreeBoundBtn;
65
66 int myClosed; // Number of free closed boundaries detected. Calculated in execute(), used in onDetect().
67 int myOpen; // Number of free open boundaries detected. Calculated in execute(), used in onDetect().
68
69private slots:
70 void ClickOnOk();
71 bool ClickOnApply();
72
73 void ActivateThisDialog();
74
78
79 void onRemoveAllClicked();
80 void onDetect();
81};
82
83#endif // REPAIRGUI_REMOVEHOLESDLG_H
Definition: DlgRef.h:93
Definition: GeometryGUI.h:74
Definition: RepairGUI_RemoveHolesDlg.h:40
Definition: RepairGUI_RemoveHolesDlg.cxx:387
void ClickOnOk()
Definition: RepairGUI_RemoveHolesDlg.cxx:146
Definition: RepairGUI_RemoveHolesDlg.cxx:306
Definition: RepairGUI_RemoveHolesDlg.cxx:325
void LineEditReturnPressed()
Definition: RepairGUI_RemoveHolesDlg.cxx:261
Definition: RepairGUI_RemoveHolesDlg.cxx:371
Definition: RepairGUI_RemoveHolesDlg.h:60
void Init()
Definition: RepairGUI_RemoveHolesDlg.cxx:109
void SetEditCurrentArgument()
Definition: RepairGUI_RemoveHolesDlg.cxx:225
DlgRef_1Sel1Check1Sel * GroupPoints
Definition: RepairGUI_RemoveHolesDlg.h:63
Definition: RepairGUI_RemoveHolesDlg.cxx:430
Definition: RepairGUI_RemoveHolesDlg.cxx:315
~RepairGUI_RemoveHolesDlg()
Definition: RepairGUI_RemoveHolesDlg.cxx:101
Definition: RepairGUI_RemoveHolesDlg.h:61
QPushButton * myFreeBoundBtn
Definition: RepairGUI_RemoveHolesDlg.h:64
RepairGUI_RemoveHolesDlg(GeometryGUI *, QWidget *=0, bool=false)
Definition: RepairGUI_RemoveHolesDlg.cxx:54
void enterEvent(QEvent *)
Definition: RepairGUI_RemoveHolesDlg.cxx:296
bool ClickOnApply()
Definition: RepairGUI_RemoveHolesDlg.cxx:157
Definition: RepairGUI_RemoveHolesDlg.cxx:274
void SelectionIntoArgument()
Definition: RepairGUI_RemoveHolesDlg.cxx:172
int myClosed
Definition: RepairGUI_RemoveHolesDlg.h:66
void onDetect()
Definition: RepairGUI_RemoveHolesDlg.cxx:413
int myOpen
Definition: RepairGUI_RemoveHolesDlg.h:67
