RepairGUI_SewingDlg.h
24// File : RepairGUI_SewingDlg.h
25// Author : Lucien PIGNOLONI, Open CASCADE S.A.S.
26//
27#ifndef REPAIRGUI_SEWINGDLG_H
28#define REPAIRGUI_SEWINGDLG_H
30#include <GEOMBase_Skeleton.h>
31
32class DlgRef_1SelExt;
33class QCheckBox;
34class SalomeApp_DoubleSpinBox;
35class QPushButton;
36
37//=================================================================================
38// class : RepairGUI_SewingDlg
39// purpose :
40//=================================================================================
42{
43 Q_OBJECT
44
45 public:
46 RepairGUI_SewingDlg( GeometryGUI*, QWidget* = 0, bool = false );
48
49protected:
50 // redefined from GEOMBase_Helper
51 virtual GEOM::GEOM_IOperations_ptr createOperation();
52 virtual bool isValid( QString& );
53 virtual bool execute( ObjectList& );
54 virtual QList<GEOM::GeomObjPtr> getSourceObjects();
55
56private:
57 void Init();
58 void enterEvent( QEvent* );
59 void initSelection();
60
61private:
62 QList<GEOM::GeomObjPtr> myObjects;
63
66 SalomeApp_DoubleSpinBox* myTolEdt;
67 QPushButton* myFreeBoundBtn;
68
69 int myClosed; // Number of free closed boundaries detected. Calculated in execute(), used in onDetect().
70 int myOpen; // Number of free open boundaries detected. Calculated in execute(), used in onDetect().
71
72private slots:
73 void ClickOnOk();
74 bool ClickOnApply();
75
76 void ActivateThisDialog();
77
81
82 void onDetect();
83};
84
85#endif // REPAIRGUI_SEWINGDLG_H
Definition: DlgRef.h:335
Definition: GeometryGUI.h:74
Definition: RepairGUI_SewingDlg.h:42
int myClosed
Definition: RepairGUI_SewingDlg.h:69
void LineEditReturnPressed()
Definition: RepairGUI_SewingDlg.cxx:213
void onDetect()
Definition: RepairGUI_SewingDlg.cxx:349
RepairGUI_SewingDlg(GeometryGUI *, QWidget *=0, bool=false)
Definition: RepairGUI_SewingDlg.cxx:54
void ClickOnOk()
Definition: RepairGUI_SewingDlg.cxx:150
void enterEvent(QEvent *)
Definition: RepairGUI_SewingDlg.cxx:248
QList< GEOM::GeomObjPtr > myObjects
Definition: RepairGUI_SewingDlg.h:62
QCheckBox * myAllowNonManifoldChk
Definition: RepairGUI_SewingDlg.h:65
Definition: RepairGUI_SewingDlg.cxx:366
Definition: RepairGUI_SewingDlg.cxx:227
void SelectionIntoArgument()
Definition: RepairGUI_SewingDlg.cxx:181
bool ClickOnApply()
Definition: RepairGUI_SewingDlg.cxx:161
SalomeApp_DoubleSpinBox * myTolEdt
Definition: RepairGUI_SewingDlg.h:66
Definition: RepairGUI_SewingDlg.cxx:335
DlgRef_1SelExt * GroupPoints
Definition: RepairGUI_SewingDlg.h:64
void Init()
Definition: RepairGUI_SewingDlg.cxx:115
Definition: RepairGUI_SewingDlg.cxx:279
Definition: RepairGUI_SewingDlg.cxx:259
int myOpen
Definition: RepairGUI_SewingDlg.h:70
void SetEditCurrentArgument()
Definition: RepairGUI_SewingDlg.cxx:199
Definition: RepairGUI_SewingDlg.cxx:268
QPushButton * myFreeBoundBtn
Definition: RepairGUI_SewingDlg.h:67
~RepairGUI_SewingDlg()
Definition: RepairGUI_SewingDlg.cxx:106
