RepairGUI_ShapeProcessDlg.h
24// File : RepairGUI_ShapeProcessDlg.h
25// Author : Lucien PIGNOLONI, Open CASCADE S.A.S.
26//
27#ifndef REPAIRGUI_SHAPEPROCESSDLG_H
28#define REPAIRGUI_SHAPEPROCESSDLG_H
30#include <GEOMBase_Skeleton.h>
31
32#include <QMap>
33
34class DlgRef_1Sel;
35class SalomeApp_IntSpinBox;
36class SalomeApp_DoubleSpinBox;
37class QCheckBox;
38class QComboBox;
39class QListWidget;
40class QListWidgetItem;
41class QStackedLayout;
42
43//=================================================================================
44// class : RepairGUI_ShapeProcessDlg
45// purpose :
46//=================================================================================
48{
49 Q_OBJECT
50
51public:
52 RepairGUI_ShapeProcessDlg( GeometryGUI*, QWidget* = 0, bool = false );
54
55protected:
56 // redefined from GEOMBase_Helper
57 virtual GEOM::GEOM_IOperations_ptr createOperation();
58 virtual bool isValid( QString& );
59 virtual bool execute( ObjectList& );
60 virtual QList<GEOM::GeomObjPtr> getSourceObjects();
61
62private:
63 void init();
64 void reset();
65 void loadDefaults(); // initialize all controls with default values (from resource file)
66
70
71 QStringList getTexts( const GEOM::string_array& );
72
73 void enterEvent( QEvent* );
74
75 QWidget* getControl( const QString& );
76 void setValue( QWidget*, const QString& ); // initialize the given control in the proper way
77 // (analyze its class and convert the value string)
78 QString getValue( QWidget* ) const; // retrieve value of the control in the proper way
79 QString getText( QWidget* ) const; // retrieve text of the control (for spin-boxes only)
80
81 //QDict<QString,QWidget*> myCtrlMap; // map of controls (values) of parameters
82 void initParamsValues(); // initialize the data structures
83 void initSelection();
84 void updateSelectAll();
85
86private:
87 QStringList myOpLst; // list of available Shape Healing Operators
88 QMap<QString,QStringList> myValMap; // map of parameters of operators
89
90 GEOM::ListOfGO_var myObjects; // selected objects
91
93 QCheckBox* mySelectAll;
95 QStackedLayout* myStack;
96
97 SalomeApp_DoubleSpinBox* myFixShapeTol3D;
98 SalomeApp_DoubleSpinBox* myFixShapeMaxTol3D;
99
100 SalomeApp_DoubleSpinBox* myFixFaceSizeTol;
101
102 SalomeApp_DoubleSpinBox* myDropSmallEdgesTol3D;
103
104 SalomeApp_DoubleSpinBox* mySplitAngleAngle;
105 SalomeApp_DoubleSpinBox* mySplitAngleMaxTol;
106
107 SalomeApp_IntSpinBox* mySplitClosedFacesNum;
108
109 SalomeApp_DoubleSpinBox* mySplitContTol3D;
112
116 SalomeApp_DoubleSpinBox* myBSplineTol3D;
117 SalomeApp_DoubleSpinBox* myBSplineTol2D;
118 SalomeApp_IntSpinBox* myBSplineDegree;
119 SalomeApp_IntSpinBox* myBSplineSegments;
120 QComboBox* myBSpline2DCont;
121 QComboBox* myBSpline3DCont;
122
126 SalomeApp_DoubleSpinBox* myToBezierMaxTol;
127
128 SalomeApp_DoubleSpinBox* mySameParameterTol3D;
129
132 SalomeApp_DoubleSpinBox* myDropSmallSolidsWidTol;
133 SalomeApp_DoubleSpinBox* myDropSmallSolidsVolTol;
135
136private slots:
137 void onOk();
138 bool onApply();
139
140 void activate();
141
143 void selectionChanged();
144 void selectClicked();
145 void advOptionToggled( bool );
146 void operatorChecked( QListWidgetItem * item );
147 void onSelectAll( int );
148};
149
150#endif // REPAIRGUI_SHAPEPROCESSDLG_H
Definition: DlgRef.h:319
Definition: GeometryGUI.h:74
Definition: RepairGUI_ShapeProcessDlg.h:48
QCheckBox * myBSpline2DCurveChk
Definition: RepairGUI_ShapeProcessDlg.h:115
Definition: RepairGUI_ShapeProcessDlg.cxx:779
SalomeApp_DoubleSpinBox * myFixShapeTol3D
Definition: RepairGUI_ShapeProcessDlg.h:97
GEOM::string_array * getParameters(const GEOM::string_array &)
Definition: RepairGUI_ShapeProcessDlg.cxx:836
QString getValue(QWidget *) const
Definition: RepairGUI_ShapeProcessDlg.cxx:573
GEOM::string_array * getActiveOperators()
Definition: RepairGUI_ShapeProcessDlg.cxx:724
SalomeApp_DoubleSpinBox * myBSplineTol3D
Definition: RepairGUI_ShapeProcessDlg.h:116
SalomeApp_DoubleSpinBox * myBSplineTol2D
Definition: RepairGUI_ShapeProcessDlg.h:117
Definition: RepairGUI_ShapeProcessDlg.cxx:905
SalomeApp_DoubleSpinBox * myDropSmallSolidsVolTol
Definition: RepairGUI_ShapeProcessDlg.h:133
void activate()
Definition: RepairGUI_ShapeProcessDlg.cxx:454
QCheckBox * myBSplineSurfModeChk
Definition: RepairGUI_ShapeProcessDlg.h:113
SalomeApp_DoubleSpinBox * mySplitAngleAngle
Definition: RepairGUI_ShapeProcessDlg.h:104
RepairGUI_ShapeProcessDlg(GeometryGUI *, QWidget *=0, bool=false)
Definition: RepairGUI_ShapeProcessDlg.cxx:61
QComboBox * mySplitContSurfCont
Definition: RepairGUI_ShapeProcessDlg.h:110
GEOM::string_array * getValues(const GEOM::string_array &)
Definition: RepairGUI_ShapeProcessDlg.cxx:866
SalomeApp_DoubleSpinBox * myFixFaceSizeTol
Definition: RepairGUI_ShapeProcessDlg.h:100
SalomeApp_DoubleSpinBox * myDropSmallEdgesTol3D
Definition: RepairGUI_ShapeProcessDlg.h:102
Definition: RepairGUI_ShapeProcessDlg.h:90
QComboBox * myBSpline2DCont
Definition: RepairGUI_ShapeProcessDlg.h:120
QCheckBox * myDropSmallSolidsVolChk
Definition: RepairGUI_ShapeProcessDlg.h:131
QComboBox * myBSpline3DCont
Definition: RepairGUI_ShapeProcessDlg.h:121
QWidget * getControl(const QString &)
Definition: RepairGUI_ShapeProcessDlg.cxx:743
Definition: RepairGUI_ShapeProcessDlg.cxx:663
QCheckBox * mySelectAll
Definition: RepairGUI_ShapeProcessDlg.h:93
QListWidget * myOpList
Definition: RepairGUI_ShapeProcessDlg.h:94
void init()
Definition: RepairGUI_ShapeProcessDlg.cxx:81
SalomeApp_IntSpinBox * mySplitClosedFacesNum
Definition: RepairGUI_ShapeProcessDlg.h:107
QCheckBox * myToBezierSurfModeChk
Definition: RepairGUI_ShapeProcessDlg.h:123
SalomeApp_DoubleSpinBox * mySplitAngleMaxTol
Definition: RepairGUI_ShapeProcessDlg.h:105
Definition: RepairGUI_ShapeProcessDlg.cxx:968
void lineEditReturnPressed()
Definition: RepairGUI_ShapeProcessDlg.cxx:444
void advOptionToggled(bool)
Definition: RepairGUI_ShapeProcessDlg.cxx:922
QStackedLayout * myStack
Definition: RepairGUI_ShapeProcessDlg.h:95
DlgRef_1Sel * mySelectWdgt
Definition: RepairGUI_ShapeProcessDlg.h:92
QCheckBox * myToBezier3DCurveChk
Definition: RepairGUI_ShapeProcessDlg.h:124
SalomeApp_IntSpinBox * myBSplineDegree
Definition: RepairGUI_ShapeProcessDlg.h:118
SalomeApp_DoubleSpinBox * myFixShapeMaxTol3D
Definition: RepairGUI_ShapeProcessDlg.h:98
SalomeApp_DoubleSpinBox * mySplitContTol3D
Definition: RepairGUI_ShapeProcessDlg.h:109
SalomeApp_DoubleSpinBox * mySameParameterTol3D
Definition: RepairGUI_ShapeProcessDlg.h:128
Definition: RepairGUI_ShapeProcessDlg.cxx:405
QCheckBox * myDropSmallSolidsMergeChk
Definition: RepairGUI_ShapeProcessDlg.h:134
~RepairGUI_ShapeProcessDlg()
Definition: RepairGUI_ShapeProcessDlg.cxx:73
QCheckBox * myToBezier2DCurveChk
Definition: RepairGUI_ShapeProcessDlg.h:125
void operatorChecked(QListWidgetItem *item)
Definition: RepairGUI_ShapeProcessDlg.cxx:958
SalomeApp_IntSpinBox * myBSplineSegments
Definition: RepairGUI_ShapeProcessDlg.h:119
Definition: RepairGUI_ShapeProcessDlg.cxx:432
Definition: RepairGUI_ShapeProcessDlg.cxx:999
QCheckBox * myBSpline3DCurveChk
Definition: RepairGUI_ShapeProcessDlg.h:114
Definition: RepairGUI_ShapeProcessDlg.cxx:616
SalomeApp_DoubleSpinBox * myDropSmallSolidsWidTol
Definition: RepairGUI_ShapeProcessDlg.h:132
QStringList myOpLst
Definition: RepairGUI_ShapeProcessDlg.h:87
SalomeApp_DoubleSpinBox * myToBezierMaxTol
Definition: RepairGUI_ShapeProcessDlg.h:126
void onSelectAll(int)
Definition: RepairGUI_ShapeProcessDlg.cxx:982
QCheckBox * myDropSmallSolidsWidChk
Definition: RepairGUI_ShapeProcessDlg.h:130
QStringList getTexts(const GEOM::string_array &)
Definition: RepairGUI_ShapeProcessDlg.cxx:884
QComboBox * mySplitContCurvCont
Definition: RepairGUI_ShapeProcessDlg.h:111
void reset()
Definition: RepairGUI_ShapeProcessDlg.cxx:481
Definition: RepairGUI_ShapeProcessDlg.cxx:625
void onOk()
Definition: RepairGUI_ShapeProcessDlg.cxx:375
bool onApply()
Definition: RepairGUI_ShapeProcessDlg.cxx:386
QMap< QString, QStringList > myValMap
Definition: RepairGUI_ShapeProcessDlg.h:88
QString getText(QWidget *) const
Definition: RepairGUI_ShapeProcessDlg.cxx:601
void setValue(QWidget *, const QString &)
Definition: RepairGUI_ShapeProcessDlg.cxx:555
void loadDefaults()
Definition: RepairGUI_ShapeProcessDlg.cxx:520
void enterEvent(QEvent *)
Definition: RepairGUI_ShapeProcessDlg.cxx:470
sequence< string > string_array
Definition: GEOM_Gen.idl:276
